SOURCE: displays "low battery" always
I had exactly this problem and found the solution - I was using the wrong type of batteries.
You might be doing the same so what you need to do is check to see what mAh the batteries you're using. I was using Energizer rechargables with 1300mAh when the camera stopped working and switched to 2500mAh rechargables (on the advice of a friend) as a last desperate attempt to get it to work and it solved my problem. I got 2500mAh Energizer rechargables and would advise the same but you should go for batteries with at least 2100mAh.
I hope this helps some people :)
SOURCE: Erratic Low Battery Warning
cudgegong said in another forum:
To resolve the annoying "change the batteries" problem. Goto menu, choose yellow menu, select
file No. reset to ON. Turn camera off and back on.
Voila fixed.
SOURCE: The camera(Fujifilm Finepix AX 250) says that the
A search of the Fujifilm website provided no answers. Try cleaning the battery contacts in the camera first with a pencil eraser and then with a cotton swab lightly dampened with rubbing alcohol. Also, I would switch to 3 or 4 sets of rechargeable batteries. That way, you always have a fresh set ready and you'll save money in the long run.
SOURCE: Hi! My Harman Kardon Go Play
First of all, here is a direct link to the ONLINE USER'S MANUAL for that model:
http://www.harmankardon.com/resources/Brands/harmankardon/Products/ProductRelatedDocuments/en-US/OwnersManual/Owner's%20Manual%20-%20Go%20+%20Play%20(English).pdf
To view the Owner's Manual with Operating Instructions just use your mouse to click on the link, which is the underlined and highlighted text just above. This will open a new web browser page automatically for you and allow you to view the information at the website indicated and the contents of the Owner's Manual.
You may need ADOBE READER installed on your computer to read PDF documents.
You can download this free at WWW.ADOBE.COM if necessary.
Click on the DOWNLOAD ADOBE READER button on right side of the ADOBE home page when you get there, then follow the onscreen instructions to install the software on your computer.
See page 4 of the manual for instructions on using batteries with the unit.
It says there that it requires 8 D-cell batteries, not the C-cells that you quoted..
Also try removing the wall adapter power supply plug to the unit when you are using batteries.
I hope that was helpful to you, good luck.
If you choose to rate this solution using the Thumbs Up scale provided, I thank you very much for your time and consideration.
Joe.
You need to replace the cmos battery. It is the little nickel sized silver disc on your motherboard. It will have the number 2032 etched on it. That is the size of the new battery you need to replace it with. Once you do that you need to optimise your bios settings or have someone do it for you.
