Have 1982 Sony SL-T7ME Colour 3 System Betamax Tape Recorder. Machine was in Standby mode,switched machine on and electrical "pop" sounded from LH side facing machine and "on" light failed to light and m/c would not open or operate. Digital clock display still working. I removed top cover and accessed the aluminium box, (after unplugging horizontal pcb mounted on top of ali box cover containing the fuses,and clock diplay pcb,s) approx 6" x 3" which has the heat-sink approx 3"x 3" at rear of box and 2 pcb's mounted vertically inside box. Checked for visual signs of electrical burnout and found 2 350v 4.7uF capacitors suspect(burn marks under capacitors pins on pcb) on primary side of pcb. Replaced with new ones and reassembled m/c, checked fuses on top,okay! Switched m/c on but still no signs of life - digital display still working. I need to have circuit diagram and some sort of diognostic info to pinpoint fault. I am nearly 100% sure fault is on primary side, probably one of the other components inside heat sink box. Output from 240v transformer behind diplay was approx 28v and still working.
  • ted5540 Aug 10, 2009
    What should be the machines operating voltage? ie the secondary winding output of transformer.
  • ted5540 Aug 12, 2009
    I have had another look inside "metal box" housing the large heat sink, checked out input voltage into primary side of vertical PCB # SR-09-1as 220v a/c.(PCB# SR-09-02 is other vertical one)
    A/C is rectified and +'ve side passes though a ceramic resistor (marked as R101 on PCB) in series with 400v 100uF capacitor (marked C108).
    Resistor has blown (open circuit) so need to know its value!!!
    This is the problem and why m/c will not power-up.
    Some writing on it appears to be (31 3 30K) if this helps you to identify it.
    Does anyone know this resistors value??????
    President:
  • 1,734 Answers
A probable source of error are the three relays on the AV-1 board. These are the relays RY401 (12V 1x UM), RY402 and RY403 (12V 2x UM). They are commercial relays. They are partially covered. Do not long trying to figure out what is broken, just renew them all.
Posted on Jul 24, 2009
Where can we get a user manual Sony Betamax SL 2000?
Try Googling (sony)(SL 2000)(manual) without parens.
Sep 06, 2017 | Sony Televison & Video
Sony dvd recorder rdr-gxd310
Click here to get the user guide and go to page # 21.
May 23, 2008 | Televison & Video
How to set up Panasonic videotape recorder
was this the one seen in the 1960 lost in space tv show meant to be in the future of the year 2000. Guess they never thought of devices being smaller or digital.
https://www.youtube.com/watch?v=VA_sd229TVM
https://www.youtube.com/watch?v=Quf6FeOnk-M
it is not a video recorder it is an audio device built in 1969
The first VCassetteR or VCR were sold by Sony in 1971.
betamax was 1975
vhs in early 1970
Aug 14, 2016 | Panasonic Vintage Rq-705 Reel To Reel Tape...
I would like to program a Universal remote control for my Sony Betamax -SL-100. Do you have the code to be able to do this?
Sony remote control have no set-up codes to betamax. If you wish to get more; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. One among it has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily.
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Jan 13, 2015 | Sony Televison & Video
How do i tune my c7 betamax to the tv without an analogue reception
The C7 has a BNC video out socket and audio out socketC to whatever the socket is on your TV and the same for the audio.
Aug 20, 2014 | Sony Betamax SL-C7 SA Vintage VCR
Betamax Hi Fi Sony Model SL -HF 100AS. Was been used after 10 years and was working fine until it failed to eject the tape. I undid the case to expose the tape and finally managed to retrieve the tape. Can...
Betamax machines are obsolete so getting hold of the parts is the biggest problem. However your best course of action might be to look at the many websites that have been set up by the enthusiastic people that Betamax attracts. If they can't help you no-one can.
Dec 02, 2010 | Televison & Video
Permanent standby
The machine is in a "fault mode", as you have figured, but it's much more likely that a motor has not completed it's cycle upon power-up. It's also possible that the load carriage is out-of-time, and will need to be set according to manual specs...accordianman
Dec 14, 2008 | Televison & Video
Old Betamax Sony SL2300 Possible Tracking problems
A common problem with this model and others is the tracking pot itself fails. Wiper in pot breaks loose. Test if the tracking control has any effect?? If not, pot is bad.
Other causes are dirty heads and tape path but, the tracking control should always have some effect on PB pic. Bad video head, tape guides loose( tape not tracking on video head correctly), guide pin problem on loading ring, slack brake problem, etc.
Nov 05, 2007 | Sony Playstation 3 (PS3) Console
DVP-NS305 DVD Player
Your system is in child lock mode. I had this exact problem this week. You need to put the system into standby mode and then press return, then enter then on/off and it will be unlocked.
Aug 28, 2007 | Sony DVP-NS305 DVD Player
Progressive feature
Hi! I had the same problem. Press the pause button on the RECORDER for 5 seconds and the progressive light will go off. Not the remote, the recorder.
Jul 19, 2007 | Sony RDR-VX530 DVD Recorder/VCR
Televison & Video Logo
239 people viewed this question
Top Televison & Video Experts
