It's possible that the wiring of the new light unit is causing the issue with the light staying on even when the oven is not in use. Here are some steps you can try to troubleshoot the problem:
- Double-check the wiring of the new light unit to ensure that it was installed correctly. Make sure that the wires are connected to the correct terminals and that there are no loose connections.
- Check the light switch to make sure that it is functioning properly. The switch may be stuck in the "on" position or may be faulty, causing the light to stay on even when the oven is not in use.
- If the wiring and switch are both functioning properly, it's possible that there is a problem with the control board or relay that controls the oven light. A professional technician may need to diagnose and repair any faulty components.
- Alternatively, you can try resetting the oven by turning off the power to the appliance for a few minutes and then turning it back on again. This can sometimes resolve issues with electronic controls.
If you're unsure of how to perform any of these steps or are uncomfortable working with electrical components, it's recommended to contact a professional technician for assistance.
