SOURCE: What does error code E7 indicate on a bush dishwasher
E7 The appliance is waiting for a signal from a flow meter. However this appliance is not fitted with a flow meter. See below for details on how to cure this fault.
For an E7 fault the PCB has to be reset:
1. With the door open, turn the appliance ‘On’
2. Within 3 secs, push the program selection button ‘P’ 4 times
The test program has been selected if ‘Soak’ and ‘Strong’ LEDs are flashing. (This combination represents the test program for appliances that have a flow meter.
1. If the above LEDs do not flash after carrying out the above procedure, then switch appliance ‘Off’ and repeat process again
Once the above test has been activated and the LEDs are illuminated then:
2. Push the program selection button ‘P’ once to select the version “without flow meter”
bullet Check that the ‘Soak’ LED is ‘Off’ and the ‘Strong’ LED is ‘Flashing’
To complete the procedure:
1. Ensure appliance is switched ‘Off’
2. Wait for approx. 10 to 15 secs
3. Switch the appliance back ‘On’
4. Select the SOAK program to test
I can’t get my dishwasher to drain, it’s full of water at the bottom and stops mid cycle and beeps, only seems to use cold water too , I’ve just tried the above
SOURCE: My. Bush dishwasher won’t drain, it’s also beeping code e7
E7The appliance is waiting for a signal from a flow meter. However this appliance is not fitted with a flow meter. See below for details on how to cure this fault.
1. With the door open, turn the appliance 'On'
2. Within 3 secs, push the program selection button 'P' 4 times
