Question about Apple iPhone Smartphone
Lcd cant see any in the screen but it rings when called,cant turn it off.i cant answer my calls and messages coz cant see any in the screen.its totaly black
  • Apple Master
  • 4,338 Answers
Try rsetting the iPhone:
Download the latest iTunes to your computer and reset the iPhone. Then re-sync it.
Reset
To reset iPhone, press and hold the Sleep/Wake button and the Home button at the same time for at least 10 seconds. During this time, a red "power off" slider may appear and the screen may go black, but do not release Sleep/Wake and Home buttons until the Apple logo appears.
If iPhone won't turn on, or the display freezes or doesn't respond
  1. Press and hold the Home button for at least six seconds, until the application you were using quits.
  2. If that doesn't work, turn iPhone off and turn it on again. Press and hold the Sleep/Wake button on top of iPhone for a few seconds until a red slider appears, and then slide the slider. Then press and hold the Sleep/Wake button until the Apple logo appears.
  3. If that doesn't work, reset iPhone. Press and hold the Sleep/Wake button and the Home button at the same time for at least ten seconds, until the Apple logo appears
More resets:
Try This:
1. Remove Sim Card
2. Hold in 'Home' button and 'On/Off' button together until Apple logo appears
3. Replace Sim Card
4. Hold in 'Home' button and 'On/Off' button together until normal phone screen appears.
Also, Try this:
1.) Shut down the iPhone 3G.
2.) Start up iTunes
3.) Hold down HOME button on the iPhone 3G
4.) While keeping the HOME button depressed, plug in the Sync cable
5.) A message will pop up to ask if you want to reset.
6.) Just click YES and the reset process should start.
Posted on Jul 24, 2009
Panasonic number ring
Answering system settings
Number of rings before the unit answers a call.You can change the number of times the phone rings "Ring count"before the unit answers calls. You can select 2 to 7 rings, or "Toll saver".The default setting is "4 rings"."Toll saver": The unit's answering system answers at the end of the 2nd ring when new messages have been recorded, or at the end of the 5th ring when there are no new messages. If you call your phone from outside to listen to new messages (page 34), you know that there are no new messages when the phone rings for the 3rd time. You can then hang up without being charged for the call.
Jan 16, 2014 | Lands Phones
I have philips landline phones. My main phone does not ring or flash when an incoming call comes in. I t won't go onto answer phone either it just rings out. I can pick it up and answer the call. i can...
Looks like the basic functions of the phone are correct. Remain the answering machine. Are you sure it can act as an answering machine?
If it can act as answering machine the reason it is not doing so may be the following.
  1. Answering function is turned OFF
  2. Answering function may be ON but the number of rings before it answers is set too high.
I suggest you try the following
Call you phone. Let it ring at least 10 times. If it can act as an answering machine it will pick up the phone and read the welcome message, because most answering machines (the recent ones at least) answer after 10 rings even if answering function is turned OFF.
The phones that can be answering machines usually do have a display that shows the number of incoming messages, or a LED that flashes to let you know that you have new recorded messages.
Jan 03, 2010 | Philips Lands Phones
Phone goes blank
sir is it blinks with white screen only or blinks with white screen then shut down?
-if the phone can receive/send text and mms messages while the incoming and outgoing calls become shut down,i think you need to replace the battery because it is weak.use only original battery.
-and if it is blink with white screen only try to reset all settings or reformat your phone,if not work hardware problem go to repair shop.
Dec 26, 2009 | Cell Phones
Phone's screen won't turn on
Fist off i have to ask what Generation Iphone do you have? and is it haxed? if it's not haxed then try this, hold the phone under a lamp, not to close though. Call your Iphone and try tilting you phone at an angle to see if you can see the screen to answer the call. Your brightness settings may have gotten adjusted so low that you cant see anything. I have seen this happen before. If you plug it in to your CPU will it light up and show the charging icon? If not then you are going to have to hard reset the phone, this sucks i know but the phone is usless right now anyway. And you can just resync it with Itunes after. Hope this helps, Cali
Jul 25, 2009 | Apple iPhone Smartphone
Cant see the lost call numbers
Hmmm. One can filter the display of various types of phone calls. Check your setting for the Messages log.
1. Open "Messages"
2. Open the "Full Menu"
3. Select "Options" (this is specific to messages, not the "Options" from the main menu which is for the phone in general).
4. Scroll through all the display filters and options and you should find the one you want.
or
1. Messages
2. Menu
3. View Folder
4. this allows you to view various types of calls.
Good luck.
Apr 19, 2009 | RIM BlackBerry Bold 9000 Smartphone
Fix phone line
It sounds to me like the phone line coming into your home has a short on it so when someone calls your phone it asts as you have answered it. Report the line trouble to your local phone provider as "RNA" (ring no answer) normal phone trouble ticket terms.
Nov 21, 2008 | Lands Phones
Vx8300 LCD cracked, cant make, recieve calls
without the screen you wont know if the phone is locked or not make sure the phone is switched on then try ringing it from a nother phone if it rings you will need to replace the screen these can be easily brought from most smaller phone shops and they will fit it for you if it dont ring the the board is probably warped if this is the case im sorry to say that you will need to replace the whole handset try ringing your no first then try answering the phone if you can do this then replace the screen if not it is not woth bothering with as it would cost to much to replace the board hope this is some help to you..................
Oct 30, 2007 | LG VX8300 Cellular Phone
Apple iPhone Smartphone Logo
164 people viewed this question
Top Apple Cell Phones Experts
Computer Repairing
Computer Repairing
Lesley Cameron
Lesley Cameron
Are you an Apple Cell Phone Expert? Answer questions, earn points and help others
