Home Logo
S
Steven DeCillis Posted on Mar 30, 2017
I have a jetted Vita Bath tub and the faucets and spout are discolored and I would like to have them replaced in brass. The tub is 16 years old. Can you help me?
5 Related Answers
Anonymous
  • 226 Answers
  • Posted on Jun 14, 2009
SOURCE: water leaks from shower head while bath faucet is running
sometimes there are orings or gaskets that get tore in assembly one of those may be bad,or if it is around the threds you might try wraping teflon tape around the thred once or twice.hope this helps
Anonymous
  • 62 Answers
  • Posted on Jul 11, 2009
SOURCE: I have a 15 year old whirlpool (not necessarily
Sorry. Its not that that easy. You will need to have a plumber advise you onsite
jpintore
  • 129 Answers
  • Posted on Oct 05, 2009
SOURCE: my delta faucet pull down diverter tub spout is
It sounds like it could be manufacture defect. Take it back for a new one.
Anonymous
  • Posted on Mar 18, 2010
SOURCE: Delta spout diverter broken cannot find direct replacement
I have a Linksys router WRT54G and i was used it on my verizon network, now i want to re-install it to another computer that i have with comcast network
The router was works well with the cable old attached, either the new one, but when I go to wireless it doesn't works
I get a strong signal but unable to get on the internet with WEP security.
With security disabled the wireless works fine. But will not connect to the
internet with WEP security on. I tried to use the CD install disk that comes
with the router but ir does not help. So i want to know what i might suppose to do?
Any help would be apreciated.
Alan
  • 80 Answers
  • Posted on Jul 04, 2010
SOURCE: I purchased my pearl jacuzzi tub about 16 years
A company called Maax bought Pearl. They are out of Canada, It would be the first place I would check, they have a website Maax.com
1helpful
We need to replace the 4 way valve for our bath tub/shower faucets. Parts from the schematic "101 - CENTRALE 4 VIE C/PROLUNGA CM.4" (Rubinetteria "SIMBOLO" Aqua Brass faucets
take the details along to a plumber supply shop ( not a hardware shop or mart) and there will be some one there that will be able to advise on parts , problems or replacement equipment
Can you fix a broken pvc pipe
more specific please. so your saying that the actual faucet sticking outta the wall is PVC and not a Brass for plated brass pipe? Also what type of valve do you have. Is it a single knob valve that you rotate to turn on as well as adjust your water temperature, or is there 2 knobs one for hot and one for cold?
A picture would help me answer your question a lot easier
Vita Bath, Paradis whirlpool tub waterfall spout leaking inside tub deck. Plumber has siliconed it, but leak remains. It seems the 2 piece spout is maybe a design flaw??
sounds like a design flaw or installation flaw. I would contact the MFg of the waterfall valve and see if they have a solution for the leak.
Silicone in something like that would be a temporary solution at best.
US PART CENTER
2answers
My bath tub faucet fills very slowly both hot and cold. All other faucets in the house have good water pressure. What could be the problem?
sounds like something stuck inside shower valve, piece of solder or something,...best to call a service guy to do this,....shouldn't be costly,....cracklin joe,......
2answers
Water leaks from shower head while bath faucet is running
How to Change White Water Whirlpool Tub Jet Hardware
First step is to remove the old hardware so you have something to compare it to. THere are two types/sizes of tub faucets on the market for deck mounted applications. If yours is mounted on the tub deck then it is a deck mounted application.
The faucet spread (distance between the threaded nipples on the bottom of the faucet) is going to be something close to 8" or it will be of variable distance. If the two handles and the spout are connected via hose then they are of variable length.
Bring the old faucet into the hardware store and compare it so you know you are getting the correct one. It is not hard but also not fun to have to adjust the holes in the tub deck to accommodate a different size.
AS for the suction.....I am assuming that you are referring to the inlet part o the pumping system and all of the equipment behind the tub. I always recommend that you use parts from the same manufacturer. It is extremely helpful to call them with all of the numbers you have to get a list of acceptable replacement parts.
Hope this helps.
Apr 27, 2009 • Home
Top Home Experts
john h
ADMIN Andrew
ADMIN Andrew
Are you a Home Expert? Answer questions, earn points and help others
