Wireing a honeywell thermostat
I am trying to replace a old mercury thermostat with a honeywell model rth3100c My old thermastat has a white wire going to W2, yellow to Y, green to G, red to R, orange to O, nothing to C or E. This is for a Heat Pump The new thermostat has terminals E, Aux,Y,G,O,L,R,B,and C Can anyone help? Thanks Bill
  • 520 Answers
Bill ..You dont have a heat pump.This controller will not work for a conventional system. Get the right thermostat
Posted on Jul 24, 2009
How do you relpace an A.C. thermostat?
E Back up heat/ white wire
AUX Jumper to E
Y yellow wire / Cooling - compressor
G Indoor fan Green wire
O Reversing valve energised in cooling most units Orange wire
L unknown. consult your manual Leave open
R Main power Red wire
B Reversing valve energised in Heat Rheem units only.
C Common second leg of power Blue wire.
Aug 30, 2014 | Honeywell RTH3100C - Digital Heat Pump...
RTH3100C thermostat for an older Lennox heat pump
well the wire on x will go to e thr r is the red wire goes to r the wire on f willgo to g the y will go to y now the rest you'll have to verfy at air handler o will go to reversing valve common wire will go to c the electric heat will go to aux
Feb 06, 2014 | Honeywell RTH3100C - Digital Heat Pump...
Replaced Bryant T-stat model TSTATBBNB001 with Honeywell t-stat
Hello,You forgot to wire the O terminal w1 witch is the reversing valve.It is important to check if old stat is using O or B in witch case B terminal=w1 leaving O unused.
Apr 21, 2010 | Honeywell Heating & Cooling
Your original wiring configuration seems to indicate that you have an air conditioner (not heat pump) and either a gas or electric furnace. If this is the case you may need a different thermostat for your application.
Apr 21, 2010 | Honeywell Heat/Cool Thermostat
I am trying to change Lennox to Honeywell
Just remember what wires went to which terminal. Usually color coded, red =R, white = W, etc, Shouldn't be too hard. Let me know if you run into a problem.
Jan 02, 2010 | Honeywell Electronic Programmable...
Heat will not shut off
Take white off of Aux, and attach it to L
Feb 16, 2009 | Honeywell Programmable Thermostat Heater
I had an old thermostat that i had to change need wiring diagram
HONEYWELL WEBSITE:
Go to honeywell.com
Under red welcome sign
Bottom red highlighted box literature/image search
Type in thermostat model number
Click on arrow to right
Then click on the PDF files owners manual / installation instructions
Dec 20, 2008 | Honeywell Electronic Programmable...
both thermostatats will have terminal designators R,W,Y,G, possibly O/B, C, W1,W2, Y1, Y2, etc.
Simplest method is to remove wires from old stat one at a time. mark where they came from and then install at same desinated terminal on the new t-stat. Hope this helps. be sure to shut off power supply to the unit (furnace) first. The wire coming to the R (RH,RC) terminal is the 24 volt a/c hot, all others are feeding back to perform given function.
Dec 20, 2008 | Honeywell Programmable Thermostat Heater
Honeywell RTH3100C
You need to go into the installer setting to change it from heatpump to single stage gas heat.Go to www.honeywell.com if youve lost them.
Dec 13, 2008 | Honeywell Programmable Thermostat Heater
Replaced thermostat on FA4ANF030 with Honeywell model rth3100c does not work
if you have a newer t-stat your heat pump reversing valve is either o or b depending on the type of system you have
Dec 02, 2007 | Heating & Cooling
Heating & Cooling Logo
314 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
