Question about Hotpoint RGB745 Gas Kitchen Range
Ge xl44 I think pilot not lit. no more snap - snap and does not light
GE xl44 stove - how do I fix the stove top. Does not light. No more snap - snap - snap when I try to ignite.
  • 83 Answers
Relace spark module if no snap snap from all burners.If one is just bad replace ignitor.
Posted on Dec 08, 2007
Oven pilot light won't light. Stove burners work fine.
if you have a pilot flame oven replace your thermocouple
if you have a newer oven you will have an ignitor
please advise me on whitch type of oven you have
Feb 05, 2013 | General Electric ge JGBS04BPW wb1k5 Oven...
The oven pilot does not light. The broiler will not work. The only thing that does is the light. GE XL44 range. The burners light and the pilots stay lit.
    If you have standing pilots, make sure the pilot for the oven/broiler is lit as well.  When you turn the thermostat up to call for heat, you should see the pilot get larger. That larger pilot flame heats a hydraulic sensor and opens the main burner valve.
    Jan 10, 2010 | GE Profile Spectra JGBP90 Gas Kitchen...
    Where is the pilotlight on a ge xl44 gas stove I belive it is in the door under the oven well I turned the gas on and stuck a flame down there and nothen took off is there a certian place to put the flame....
    In general lets be clear. The OVEN pilot is located under the oven door at the top of the Broiler.It is a small piece of metal just before the GAS safety Valve which acts on temperature so gas won't flow unless Pilot is lit,That's the OVEN PILOT.The stove's RANGE is the top burners where you heat Pots and Pans.It has either 2 Pilot lights that connect the burners to the Flame they are under the Range Top.Newer Models use electronic ignitions no flame.Please note if you had your stove/oven disconected or Gas off when you turn it back on there will be air in the line that needs to escape before you light.This is why in NYC when Utility on steet main the MUST re-light your appliances.Be Careful with Gas.Good Luck.
    Sep 19, 2009 | Ovens
    Getting to the Pilot
    Your model JGBP28DED2WH uses spark ignition on the stove top burners, and a glow bar ignitor, part number WB2X9154 for the oven and broiler. To get to the bake ignitor if oven will not light: Take the racks out of the oven. Remove oven floor by removing two screws at back of oven floor and lifting floor. Remove the square metal flame spreader to get to the burner / ignitor assembly. (note: The ignitor may still glow when you try it, but usually is still the problem)
    Feb 22, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
    GE Spectra XL 44 Gas Oven Bottom Heating
    you will need a new heating element at the bottom. to find the part, go to ge's website and get the model #- you should be able to find it either online or a service center.
    Apr 28, 2008 | Kitchen Ranges
    Stove top pilot light
    I have a GE Gas Stove XL44 the stove top buners don't light by themselves without manual lighting. When I turn on the buner knob the buner doesn't click. Also I used my self- cleaning oven for the first time and stopped it before the time was up after that is when the stove top buners wouldn't light by theirselves.
    Jan 20, 2008 | GE Profile Spectra JGBP90 Gas Kitchen...
    GE XL44 Gas Stove
    Hi I have a GE X44 gas stove. The 4 top burners work just fine, but the oven no longer turns on. I don't see the blue flame inside the oven. Is it safe to relight the pilot light?????
    Nov 08, 2007 | GE Profile Spectra JGBP90 Gas Kitchen...
    GE XL44 Range
    The pilot light is lit to light the main burner. First off, is your pilot light lit or is the igniter lit. There are two thermal sensor in the oven. One is above your pilot light and will not let the pilot light stay lit unless there is a flame. Secondly, you have a thermal sensor in your oven wired all the way to the switch to turn the oven on. If it thinks that it is at temp, then it will never turn on. This sensor may become bad or the case of my oven break. But if these are good, you many have a clogged burning unit underneath. Cleaning according to the owners manual may correct that. Check your owners manual to see what is user serviceable. Gas is nothing to play with.
    Apr 20, 2007 | GE Profile Spectra JGBP90 Gas Kitchen...
    Hotpoint RGB745 Gas Kitchen Range Logo
    772 people viewed this question
    Top Hotpoint Kitchen Ranges Experts
    Dan Webster
    Dan Webster
    Ismael Rodriguez...
    Justin Duby
    Justin Duby
    Are you a Hotpoint Kitchen Range Expert? Answer questions, earn points and help others
