Question about Kenwood Car Audio & Video
I need to know where to hook up the key hot wire on a 2005 gmc sierra?
  • 1,305 Answers
To find where to hook up your power lead. The best way is with an inexpensive test light. You can get one at the local auto parts house. It looks like a screwdriver with a light-up handle and a wire pigtail on one end and instead of a screwblade it's got an ice-pick like tip.
Connect the aligator clip end to a metal grounding location under the dash, and then with the key on, probe with the pointed end on some of the wiring near the fuse block or under the steering column. When the light in the test light illuminates, you've found a hot. Now turn the key off and see if the light goes out. That will be your hot for the the accessory hot.
Then you'll most likely need to find a constant hot. This will be a wire that illuminates your test light whether the key is on or off. This one is hooked to the hot that is constant...it's the one that keeps all your radio stations and the memory items intact when the key is turned off.
So you'll have 2 a constant hot and an "accessory" hot that's only on with the key.
If you need wiring diagrams for your car, let me know.
K
Posted on Jul 24, 2009
Blower motor not working 2005 GMC sierra resister ground pin burnt
small_car4.png Wiring problem of the 2005 GMC Sierra 1500 6 Failure Date: 07/18/2009
The connector that plugs into the blower motor under the glove box became too hot and melted the plastic resulting in the a/c and heat not to work (this includes the windshield defroster). I've been looking up problems and solutions and found that this is a recurring problem with GMC and chevy trucks yet there has not been any recall, in fact the dealerships have an extremely overpriced kit to fix their faulty wiring. About 66,000 mi.
Oct 12, 2014 | 2005 GMC Sierra
The heater wont switch from hot to cold on drivers side on a 2005 gmc sierra nevada edition 5.3 motor
the air temp actuator for the driver side probably needs to be replaced. mine is doing the same thing on a 2004 gmc sierra.
Jul 06, 2012 | 2005 GMC Sierra
I need a free factory wiring diagram for a 2005 gmc sierra 2500
try a search on Google ,the only places I know want paid for their services
May 08, 2012 | 2005 GMC Sierra
I need an Illustrated Parts Break down for a 1989 GMC Sierra 1500. 350 w/ PS/PB loaded. Steering column Removal Repair or Replace
Hi.
Below you get all the parts breakdown for GMC Sierra 1500, including steering column assembly:
1500 SIERRA
Here diagrams for all 1989 GMC trucks.
If you need to take apart the steering column you will also need wiring. below the color codes and wiring tips:
GMC SIERRA 1988-2005 VEHICLE WIRING
Regards.
Ginko
Aug 31, 2011 | GMC C1500 Cars & Trucks
I have a 2005 GMC Sierra. When I hook up a
G'day mate on the plug at the vehicle tow bar is the earth circut from plug hooked to vehicle and getting complete curciut ?
Mar 29, 2010 | 2005 GMC Sierra
Engine wont start with the key in ignition. Can
the first thing is to check all connection to battery then check the ignition switch not the key part but the electrical switch in column. start there
Dec 19, 2009 | 2005 GMC Sierra
I need to know how to install a egr valve in a 05 duramax disel GMC sierra
Once you are able to identify the EGR, you simply unbolt the valve and ant other obstaructing part. Clean its surface of carbon. Repalce the gasket if worn. Any sticky bolt/nut that you encounter could be removed by spraying some WD-40 around them. Also disconnect the negative wire of the battery first. Diesel do run hot, so get ready for some hard bolts to loosen.
Oct 21, 2009 | 2005 GMC Sierra 2500HD 4WD
Where to hook up an extra red wired that comes out of the switch
Does the wire go to key power to light up the switch when the key is on.
Apr 24, 2009 | 2002 GMC Sierra
Car Audio & Video Logo
77 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
