Back to:
Tags:
Compaq Presario M2000 PC Notebook
No screen (by 2 users)
posted by Okie Mac on Nov 21, 2007
Unit powers up- can see the Compaq logo flash very dim, but can't see Windows screen.
I have the same problem Post a new problem
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
1 Other User Has The Same Problem
Comment by eneal1081, posted on Dec 19, 2007
I had the same problem in my M2000 and found out that indeed the blacklight was not working. There are two common causes for the problem, and the cheapest/easiest and perhaps most common problem is the inverter. I found one on an online auction site, and it fixed my problem. The other problem could be a broken bulb. If your laptop was dropped, then this could be the case. If the bulb is broken, then you will be best off buying a new laptop or finding a used screen. With the age of the laptop, there is no sense throwing a bunch of money at the problem IMHO. My inverter cost about $60, while screens were running about $150 and up. If you find a replacement screen for cheap, it also includes the inverter so it would be a pretty sure fix.
If you decide to go the new laptop route, you can still use the broken laptop as a spare desktop by plugging it into a monitor, USB keyboard, and USB mouse. From the sound of your problem, the computer works fine but the screen does not.
Solution #1
posted on Nov 21, 2007
Not Rated (0)
Cstufftek
Rank:Guru Guru
Rating: 86%, 118 votes
The backlight in your LCD most likely needs to be replaced.if you are not familiar with it's removal and installation I suggest you take it in to a repair shop.
Hope this helps you..
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on No screen:
I don't want to Accept this solution
Can you Help with these PC Laptops problems?
my laptop haven't sound. plz hlp me soon.
Hi I have been having some problems with my presario...
My compaq presario recently shut down due to power...
i have a problem about my neo laptop/notebook. the monitor...
Had for a while and suddenly my wireless adapter has...
Loading problems.
Repair Service
Find PC Laptop Repair Service Provider Near You:
Browse the Repair Service Directory
Repair Service Providers, Get Listed FREE
Prescreened Contractors
Get Matched to Prescreened Computer Professionals
Category
Zip code
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
