Question about Refrigerators
My admiral fridge freezes food in the refrigerator section
The refrigerator will work ok for a couple of days and all of a sudden, BINGO all the food is frozen.
Does anyone have an answer??
    Sergeant:
  • 202 Answers
Timer or thermostat nor working
Posted on Jul 24, 2009
  • 3 Answers
I have the same problem with our Admiral. We've had two service calls on it in the three years we have owned it. The first call was because the freezer was completely iced up. Behind the plastic in the freezer was a huge glacier. The ice went clear down into the top part of the refrigerator section, Repairman had to use a steamer for a long time to get the ice to melt. He replaced the thermostat. But a few months later we lost power completely. Turns out the ice had expanded a power connector inside the unit. Now it just freezes. So it isn't the thermostat or timer because they have been checked and replaced. I think this is just an inferior product. I wish I hadn't purchased it. I will not buy anything Maytag makes just because of this horror of an appliance. The solution to your problem is through the crappy thing out and get a new one that isn't a Maytag product. (Our electric company will haul it away and give me a $50 credit)
Posted on Jul 27, 2010
Fridge is freezing food
you can usually adjust he thermostat inside the fridge.... can be located anywhere. Try checking the manual if you still got it.
Apr 01, 2015 | Admiral 26 cu. ft. Side-By-Side...
Food freezing in crispers in ge bottom freezer fridge
Check to see if the fan is working...put a thermometer in the refrigerator and make sure the temps are between 33-41 degrees F.
Dec 18, 2013 | GE Refrigerators
Admiral american fridge freezer constantly blowing cold air into fridge compartment.
Changing the freezer settings won't really make a difference because regardless its still going to be freezing. The way the machine works is the freezer cools the fridge, and there should be a control in the fridge that operates the baffles in the airway between the freezer and fridge and reduces the amount of air that enters into the fresh food section.
Jun 17, 2012 | Admiral 26 cu. ft. Side-By-Side...
Samsung sr s2026cvw problem FRIDGE FREEZER: This freezes in the bottom of the fridge, freezing my vegetables? What needs replacing? Comet came last March and replaced something in the back but I don't...
There can be many reasons why your refrigerator is freezing your food. To see what could be happening and to figure out how to possibly fix your problem. Take a look at this tip which contains many of the causes and solutions to fix the problems.
Refrigerator is Too Cold and Freezing Food
heatman101
Dec 21, 2010 | Refrigerators
Refrigerator freezes fresh food section and always runs
Please read it appears that there are two defrost timers for your refrigerator one for the freezer one for the refrigerator
http://www.partselect.com/PartDetail.aspx?Inventory=310858&SourceCode=4#RepairStory
May 02, 2009 | GE Refrigerators
Admiral SAC224 fridge freezer: fridge intermittently freezes up
To Whiteorchid,
Found a fix for my issue ... hopefully it'll help you.
Up at the topleft rearmost corner of the fridge remove panel to reveal spring attached slots where cold is supplied from freezer. The spring attached had came off one end as there isn't a "slot" for the spring to hold in place (design fault?).Reattached the spring and taped on .... and hey presto fridge now working perfectly again. Hope this helps.
Sep 01, 2008 | Admiral 26 cu. ft. Side-By-Side...
Admiral 23ADiW side by side fridge freezer
Is the back of the freezer section iced up?
If so you could have a defrost problem. All the cooling components are in the freezer section there is a damper controlled by a dial in the refrigerator that opens and closes.
If the damper is closed it will not allow air into refrigerator section. It is seperate from the Thermostat.
If the damer is opened to much you can start freezing food in the refrigerator section.
If there is ice on the back wall of the freezer section. It is not defrosting. There are 3 parts in the defrost process. The thermination stat, the heater, and the defrost timer or it's a timer on the electronic board behind the metal plate on the back of the refrigerator.
Good Luck
May 20, 2008 | Admiral 26 cu. ft. Side-By-Side...
Admiral - GC2224GEKB
Does freezer cool like the cold food section? Did this suddenly happen, and frozen food began to thaw?  Most freezers control the cooling in the cold food section. The freezer must work fine before the cold food section will work fine. Let us know more, Thanks JT
Oct 24, 2007 | Admiral 26 cu. ft. Side-By-Side...
The water filter keeps freezing and food in door and on shelves keeps freezing.
clean lint from coils in back. could also be low on refrigerant (freon)
Jul 09, 2007 | Admiral 26 cu. ft. Side-By-Side...
Refrigerators Logo
184 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
