Question about Fuji FinePix S700 Digital Camera
Re: turning on s700
I turn on my s700, and I get a whole bunch of vertical lines--purple, light blue, dark purple, pink-purple, (mostly in the reddish/purple phase. Is this from moisture, or from a drop? I do use my camera on hiking trips, and carry it in a Lowe Pro shoulder bag (which gives it some protection, but not full protection).
At first, I thought it was a battery prob. But no, I charged the batteries, popped them back in, and still, same result.
Any ideas? Would it be the LCD display?
How are your pictures coming out? If the photos you take after seeing these lines come out good, then it could be the LCD only. However, if you are unable to shoot, or the photo files are damaged, there may be a problem internally. You should contact Fuji to see if they have heard of this problem, and if not, contact local camera shops to see if they can take a look at it. Also, digital cameras and card will only last so long - they will wear out much sooner than their film counterparts did.
Posted on Jul 25, 2009
What's wrong with my camera?
I think that you need a professional's help on this one
Jul 09, 2015 | Panasonic Lumix DMC-FZ28 Digital Camera
Tablet wont turn on
Blue means that your system is not charging, when it is charging it should be pink/purple. when the battery is full it will turn blue. If the blue/pink light stay on it may mean that your battery is no longer charging completely. If it is still under warranty, get a replacement battery for free... otherwise it may be time to invest in a new battery.
Jan 16, 2014 | Computers & Internet
Where can i get a wiring diagram for my 2002 chrysler neon auto
12V CONSTANT WIRE RED and PINK/BLACK Ignition harness
12V IGNITION WIRE DARK BLUE Ignition harness
12V ACCESSORY WIRE BLACK/ORANGE Ignition harness
STARTER WIRE YELLOW Ignition harness
PARKING LIGHTS (+) BLACK/YELLOW At Headlight switch
POWER DOOR LOCK (5-wire reverse polarity) ORANGE/PURPLE Harness Coming Into Vehicle From Driver's
Door
POWER DOOR UNLOCK (5-wire reverse
polarity)
PINK/PURPLE Harness Coming Into Vehicle From Driver's
Door
DOOR TRIGGER (-) YELLOW/BLACK At Headlight Switch
DOMELIGHT SUPERVISION (-) Use door trigger
TRUNK TRIGGER (-) GRAY/BLACK At Light In Trunk
TACHOMETER WIRE TAN/BLUE or BLACK/GRAY At Ignition Coil
BRAKE WIRE (+) WHITE/BROWN At Brake Pedal Switch
HORN TRIGGER (-) BLACK/RED Harness Coming From Steering Wheel At
Column
CAUTION! SRS airbag wires are not enclosed in protective loom at the steering column. They are a twisted pair of wires that run with rest of
ignition harness. Be careful not to cut or probe these wires.
Radio:
(Black plug)
Rear Right speaker -: Blue w/White stripe
Rear Left speaker -: Brown w/Yellow stripe
Front Right +: Purple
Front Left +: Dark Green
Rear Right speaker +: Blue w/Orange Stripe
Rear Left speaker +: Brown w/Blue Stripe
Power Antenna/Amp: White
(Gray Plug)
+12v battery wire: Pink or Pink w/White Stripe
+12v Ignition wire: Red w/ White Stripe
Front Right speaker -: Blue w/ Red Stripe
Front Left speaker -: Brown w/ Red Stripe
May 03, 2011 | 2002 Dodge Neon
I'm having trouble connecting my alpine cde-9852 to my 96 jeep cherokee. is there a wiring diagram online for this? thanks
Constant 12V+ Pink Switched 12V+ Purple/White Ground Black Illumination Light Blue/Red Dimmer Orange Antenna Right Front Front Speakers 5 1/4" Doors Left Front (+) Dark Green Left Front (-) Brown/Red Right Front (+) Purple Right Front (-) Dark Blue/Red Rear Speakers 5 1/4" Rear Deck Left Rear (+) Brown/Yellow Left Rear (-) Brown/Light Blue Right Rear (+) Dark Blue/White Right Rear (-) Dark Blue/Orange
Jul 11, 2009 | Alpine CDE-9852 CD Player
Old pink and purple bathroom needs help.
The consensus here is a medium to pale/light blue - black or dark blue would blend better, but it would be one darn dark bathroom. You want something that blends, not accentuates the purple.
Hope this helps :)
Mar 10, 2009 | Samsung HCN653W 65" Rear Projection...
Oem Radio installation
*** 91 park ave with delco bose =
black = ground
dark green = lights on input
grey = panel lights
pink = on input
yellow = power input
orange = battery power input
nca = shield ground
tan = left fr spkr +
orange/black = left & right spkr -neg
lite green = right fr spkr +
nca = shield ground
dark blue = right rear spkr +
dark green/yellow = right & left spkr - neg
brown = left rear spkr +
purple/white = display dim output
pink = vehicle speed input
**** 91 park ave without delco bose =
grey = left front - neg
tan = left front + pos
dark green = right front - neg
light green = right front + pos
black = ground
dark green = display dim signal
grey = panel lights
pink = power antanna
yellow = ign input
light blue = right rear - neg
dark blue = right rear + pos
yellow = left rear - neg
brown = left rear + pos .
there YA go
Dec 27, 2008 | 1991 Buick Park Avenue
Sony Cyber-shot DSC-S700 photos are pink/purple.
I have the same problem with my Sony cybershot DSC-T20. Ive only had it a year. Please could someone help me.
Sep 10, 2008 | Sony Cyber-shot DSC-S700 Digital Camera
1998 ford el xr6, need stereo wiring harness colours
You did not specify if you wanted the wiring diagram for the Expedition or the Explorer, so I got you both. Good Luck
1998 Ford Expedition Stereo Wiring
Constant 12V+ White/Purple Switched 12V+ Black/Pink Ground Black/Green Illumination Blue/Black Dimmer n/a Amplifier Remote Blue Antenna Right Front Front Speakers 6" x 8" Doors Left Front (+) Light Blue/White Left Front (-) Orange/Light Green Right Front (+) Dark Green/Orange Right Front (-) White/Light Green Rear Speakers 6" x 8" Rear Doors Left Rear (+) Tan/Yellow Left Rear (-) Gray/Light Blue Right Rear (+) Brown/Pink Right Rear (-) Orange/Red
1998 Ford Explorer Stereo Wiring Constant 12V+ Light Green Switched 12V+ Yellow/Black Ground Black Illumination Light Blue/Red Dimmer n/a Antenna Trigger Orange/Blue Antenna Right Front Front Speakers 5" x 7" Doors Left Front (+) Orange/Light Green Left Front (-) Light Blue/White Right Front (+) Dark Green/Orange Right Front (-) White/Light Green Rear Speakers 5" x 7" Rear Door Left Rear (+) Gray/Light Blue Left Rear (-) Tan/Yellow Right Rear (+) Orange/Red Right Rear (-) Brown/Pink
Feb 22, 2008 | Car Audio & Video
No picture/vertical lines on screen
it's called retrace lines ,your screens are set to high or focus block assy which has the screen adjustments on it also is faulty
Apr 17, 2007 | Sony KP-53S65 53" Rear Projection...
Fuji FinePix S700 Digital Camera Logo
132 people viewed this question
Top Fuji Cameras Experts
Greg Cann
Greg Cann
Are you a Fuji Camera Expert? Answer questions, earn points and help others
