Sewing Machines Logo
Ann shellabear Posted on Mar 30, 2017
My question is can I iron on rubber backed curtaining before I sew the hem??
2 Related Answers
Anonymous
  • 111 Answers
  • Posted on Jul 23, 2009
SOURCE: stitching problem
bunching up on the bottom means that there is no upper tension...
99rannellis
R.A. Ellis
  • 12731 Answers
  • Posted on Dec 21, 2016
SOURCE: Sewing a hem on a sheer (rayon ?) curtain and it puckered slightly along the seamline Used sz 11 ballpoint needle with 40wt rayon thread. Tried tiny stitches then longer ones. Any suggestions??
Sewing sheer fabric is challenging, even with the best machine and the correct settings. The problem is that the fabric is so light weight that it lacks body. Besides using paper or tissue as suggested, you can also incorporate a wash-away stabilizer with the fabric at the time of sewing. It will add body to the fabric but will wash away easily when finished.
BTW, since the fabric you are sewing is rayon, it is knitted or woven? If it is a woven fabric, be sure to use a sharp needle. If it is knitted, then use a ball-point needle.
Sewing With Sheer Fabrics 3 Must Know Methods
Sheer Fabrics EmmaOneSock Sewing Tutorials
How to hem sheer or lightweight fabrics So Sew Easy
Sewing hems on curtains without stitch showing?
That would be a blind stitch but be aware that even blind stitches may still show. To be absolutely sure the stitches don't show, you may want to consider hand stitching the hem in place.
How To Sew Blind Hem Stitch
Keep breaking needles when i put down presser foot to sew iwant to sew straight stich to hem a curtain
If the needle is hitting something, make sure you have the machine set for straight stitch and the needle is in the center position. If it is still hitting and breaking, then the machine is out of adjustment and needs to be repaired.
Which stitch is best for hemming curtains? I have a ajanome Mystyle36
Probably depends on the fabric and the look you want. You can use a blind hem stitch if you don't want the stitch to show from the front of the fabric, or you can use a simple straight stitch or possible use a twin needle (if you machine accommodates it).
https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=1&ved=0ahUKEwisl4Of5cTRAhUKqlQKHcZuAN0QFggeMAA&url=http%3A%2F%2Fjanome.com%2Fsiteassets%2Fsupport%2Fmanuals%2Feconomy-models%2Finst-book-7318-english.pdf&usg=AFQjCNETNSS3UbZEcBkH9FIWGMpqxsnDNw&cad=rja
2answers
well aside from trying all the normal things like thread tension adjustments and such , another neet little method is to use a flat piece of thin tissue paper (sew right thru it ) layed over fabric , this will add the stiffness to fabric u may need to complete this task, then very slow and carefull tear the paper away from it to leave the threads behind!! if you think you can get away with it use tissue paper on back side and leave it there , hey holds a hem and pleats real nice !!
Can you do a coverstitch on the Brother 634D serger
I don't think so, the D in your model name would denote that it has Differential feeding but is probably a 3/4 Marrowing stitch only. So this means it would do 3 thread overlock, 4 thread overlock and you can probably set it up for rolled hemming too.
Coverstitch is fairly new to home sergers and is available on some machines along with the 3 and 4 thread stitches, but changing between the regular overlock and a coverstitch takes a few minutes. The model number will usually have a "C" in the name. Also, during coverstitch the blades are disenaged and don't trim your fabric so you still need often to go back with blunt scissors and trim the raw edge.
And sewing coverstitch can be finicky, with skipped stitches a problem. Use high quality thread and XL (extra long) or SUX (stretch extra long) needles to avoid this.
However some manufacturers are now making dedicated coverstitch machines; if you are assembling a garment with your regular serger, you can then just move over to the coverstitch machine to sew the hems and necklines and not spend 20 mins changing over your machine's functions. Much more productive.
You may wish to check out the Brother 2340CV, this is their dedicated domestic coverstitch machine. Link to product info is http://www.brother-usa.com/homesewing/ModelDetail.aspx?ProductID=2340CV
In the meantime, best solution is a twin needle to stitch the hem from the right side of the garment on your regular sewing machine, looks much the same, and you can get twin needles with a 4mm or 2.2 mm gap and in stretch and sharp tips for less than $10 each. Just iron up the hem about 1.5cm deep, and thread up your sewing machine with the twin needle and two spools of same colour on top (I just wind an extra bobbin and use this plus the original thread spool rather than buy two spools).
Just sew really slow as the twin needle builds up a lot of heat and will break if you push it along. I use this finish on all my knit garments and it works just fine. Sometimes I'll iron in a 2cm strip of fusible web inside the hem to give it some firmness in a neckline, then twin needle stitch at about 1.7 from the folded edge.
Hope this answers your question.
Stitching problem
What is a Narrow double hem with hand slip
You can find some instructions on a narrow double hem at http://www.sewjanetmoville.co.uk/content/learning/viewArticle.asp?lcArticleCategoryID=0&lcArticleID=3&pgid=learningCentre. Instead of machine sewing it, use a hand slip stitch as seen here: http://www.hutchal.clara.net/curtains/sewguide.htm.
You can find more info on these techniques at http://www.repair-home.com/how_to_sew_repairs.html
Hope this helps! Let me know if you need more info.
6helpful
5answers
Coverstitching on White Speedylock serger
Your machine cannot do a cover stitch. Check the Brother website, they make a cover stitch only machine, it works much better than any of the serger/cover stitch combination machines, and it is a lot less money.
Top Sewing Machines Experts
SmartAviator
SmartAviator
Are you a Sewing Machine Expert? Answer questions, earn points and help others
