Question about Philips 50PFP5332D 50 in. Plasma Television
Unit just clicks when plugged in
I also noticed two green lights flashing inside the rear of the unit as it clicks.
  • 10 Answers
I have the same tv and the fix was the power supply board that had 5 capacitors that were blown. there was a black goo on the top of the capacitors. The power supply board is in the middle top of the tv once you pull the back off. replace the bad caps and you should be back in business. My 50 inch plasma fix costed $5 in parts (5 capacitors) and $9 in shipping fees. Much better than the repair shop. If you know someone who can solder for you or if you can do it yourself, it's very easy to fix.
Posted on Jul 24, 2009
  • Rachel Cotter
    Rachel Cotter Oct 12, 2016
    All the capacitors look normal which ones should I replace?
I have an old Carrier N1340 air conditioner that works when switched on, green light flashes 4 times, for a few times then it shuts down. There is also a flashing red light inside that unit.
There will be a list of flash codes in your manual or on the inside cover of the unit indicating what the problem is eg. low pressure or high pressure alarm
Nov 15, 2016 | Carrier Heating & Cooling
Mitsubishi ws48515 when plugged in hear a click and the green light starts blinking and set does nothing
This is a common problem with this unit.
1. Un plug the unit.
2. Take the back off of the unit
3. On the far left side you will see metal box standing up. Inside the box is your DM board. Remove the box from the unit.
4. Remove the DM board from the box.
5. Inspect these Capacitors to see if they are bulging or defective.
C81A2, C81A3, C81B3 and C81B4. The Value of these capacitors are 1000MF/16V
6. If any of these capacitors are defective, replace them all with capacitors at this rating. 680MF/16V
7. Make sure that when you replace the capacitors that you have the correct polarity. The - side of the capacitor goes toward the markings on the board.
8. Reinstall all parts of unit.
9. Plug in unit
10. Wait the 90 seconds or so that it takes for the DM to boot up ( Green Flashing Light )
11. Once Unit stops flashing you should be able to turn it on and enjoy.
Good luck to you.
Mar 20, 2013 | Televison & Video
It flashes a white/ yellow light then flashes red. will not power on to green.
you need a new playstation i would think you have the yellow light of death my friend google up (ylod) and it will better explain it for you
Dec 21, 2010 | Sony Playstation 3 (PS3) Console
I have a mitsubishi air conditioning unit model MUH-12v. The fan on the machine outside has stopped and of course inside the air is not cold. Could this be a problem with replacing the gas or could it be a...
Here is a tip about Mitsubishi Air Conditioners and how to get the manuals for all of the mitsubishi line. The manual include both troubleshooting and installation.
Mitsubishi Air Conditioner Troubleshooting and Repair
Aug 30, 2010 | Heating & Cooling
Green light flashing on back of unit near power cord also green light flashing on motherboard near power supply plug in.
I would suggest trying to replace the power supply. If that does not fix the issue, i would need to hear more about the computer.
May 06, 2009 | Sony VAIO VGC-RB40 PC Desktop
The Power Light is Red
yeah, should stay red when unit is turned off, indicating there's power but it's doing nothing.
Per user manual:
Solid red - power off (standby mode)
blinking red - power off (now cooling)
blinking green - power on (preparing to light lamp)
solid green - power on
Mar 08, 2009 | Panasonic PT-40LC12 40" Rear Projection...
WD-62525 green timer light keeps blinking after lamp replacement
Did you let the green light flash for about 70 seconds? It goes thru a self check when plugged in and takes a little time
Dec 29, 2008 | Mitsubishi WD-62525 62" Rear Projection...
Mitsubishi vs-5043 Shuts Down
do you get any "blinking/flashing green/red light" ?
Dec 02, 2007 | Mitsubishi VS-5043 50" Rear Projection...
Philips 50PFP5332D 50 in. Plasma Television Logo
254 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
