Question about Motorola Mobility L6 Cellular Phone
Can't receive calls
My Motorola L6 works perfectly except last week I noticed that whenever a call was coming in, the phone's screen went blank...I am able to make calls, send text, use all phone features except receiving calls or looking at the 'received calls' feature.
Is there anything I can do about it?
    Problem Solver:
  • 5 Answers
Re: can't receive calls
Majer of peoples suffer with this problem .........................
just do flash u r phone with help of flash saftwere
Posted on Dec 02, 2007
0 characters
3 Points
Sony Ericsson W580i screen went blank
Ok, my phone had the same problem. I took the face plate off and the screen out and there's actually a little connector that connects to a board behind the screen(can come unplugged for replacement). I fiddled around a little with it and it worked fine. about a week or 2 later it happened again. I tried fixing it again and it would just flash white>black>lines>white, repeat. I know my phone's taken a bit of abuse, dropped down a road, soaked in rain, but it always worked after. These phone screens aren't meant to take abuse. Problem; the phone screen died. Solution; get a new screen.
Apr 20, 2009 | AT&T Sony Ericsson W580i Cell Phone -...
Moto razr v3 is acting up
you need to reflash the phone
Oct 01, 2008 | Motorola Mobility RAZR V3
from your cell phone dile in the cell # and send it. that should bring you to your voicemail.
if that wont work try taking out any memory cards or any other accessorys the phone may have.
If you have voice recognition on your phone try using that to get to your voicemail.
Aug 06, 2008 | Motorola Mobility L6 Cellular Phone
Blank screen
apparently you damaged your flex cable that connects the main board to the lcd - hence your calls work , but nothing on screen - to repair it costs - $25-40
Jan 23, 2008 | Motorola Mobility L6 Cellular Phone
Motorola L6: how to change the # VM dials
Motorola L6 Keypad Layout
  1. From the stand by screen, press the Menu key.
  2. Scroll to and select Messages.
  3. Scroll to "Voicemail" and press the Menu key.
  4. Scroll to and select Voicemail setup.
  5. Select Voicemail No.
  6. View or edit the Mailbox Retrieval number, then select OK.
    Note: If the Voice Mail Retrieval number is unknown, contact Customer Care for the users local number or to have programming sent to the device.
Dec 13, 2007 | Motorola Mobility L6 Cellular Phone
Razor screen went blank
i tried some electrical contact cleaner (brake cleaner WAL-MART .89 cents) on the hinges. Open ti back and forth several times. NOTE: do not spray alot, just a little at a time. Then it got squeaky and started working. Then I sprayed a little WD-40 on the hinges and it works fine.
Nov 16, 2007 | Motorola Mobility RAZR V3
Screen is blank
If you have a USB cable and the right software you can still get the information off your phone.
Aug 24, 2007 | Motorola Mobility RAZR V3m Cellular Phone
Motorola Mobility L6 Cellular Phone Logo
152 people viewed this question
Top Motorola Mobility Cell Phones Experts
D. E. Hev
Chris Hunt
Lawrence Oravetz
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
