Question about Heath Zenith 270 Degree Replacement Motion Sensor - White, SL-5716-WH
Heath Zenith Wireless Motion Sensor stays on all the time. Have checked the dip switch settings put in fresh batteries, made sure the sensors are well within range of base light, no objects blocking path between sensor and light base. Have setting on dusk - dawn. Any ideas ??
5 Suggested Answers
falspet
  • 438 Answers
SOURCE: I have a Zenith motion sensor light that has
replace the unit, they are cheep and easier to replace than to service.
Posted on Jan 31, 2010
  • 54 Answers
SOURCE: I have a sensor that stays on all night when the
Your motion detector is based on infrared or heat sensing technology. Moving air or wind will make your unit more sensitive to false alarming. Here are a few things for you to check: 1) make sure your unit is sealed. Any holes or openings in the unit's casing will affect operation. 2) you may need to readjust the unit's sensitivity. There may be an adjustment pod or jumper inside the detector to reduce sensitivity. 3) make sure the unit is mounted securely. If the wind causes the detector to move, even slightly, this could be the cause of your problem.
Posted on Feb 02, 2010
  • 250 Answers
SOURCE: need to wire motion sensor to light, have three
The black wire goes with the black house supply wire, and the red wire goes with the black wire from the lighting fixture. The white wires all connect together.
Posted on Feb 22, 2010
  • 5603 Answers
SOURCE: Hi I have a dusk to dawn motion light. It is the
Some of these fixtures have a function built in that turns the light on solid if the power is cycled rapidly several times. If you have had power glitches and this unit has that function, it might be locked on.
Pull the circuit breaker for the light for a couple minutes then try re-powering it to reset the function.
Posted on Jun 08, 2010
Defiant 270 Degree White Replacement Motion Sensor manual
i ave a live switch leg no switch wil sensor function correctly or will it always stay on?
Oct 17, 2013 | Heath Zenith 270 Degree Replacement Motion...
Need the manuel for setting heath zenith lamp module model no BC-465
i have a question about heath zenith motion sensor light.
i put up two new Heath Zenith Motion Sensor Light Control the i buy from home depot tie into switch leg. When i put in on test it work fine stay on for a few second them off, but when i set up on automatic Time-1min.\ Dual Brite-off \ Lamp Mode-Normal light go off and them come back on for the rest of the nigh long and go off morning time. Any body have this problem?
Jul 06, 2012 | Heath Zenith Secure Home Motion Activated...
The lights stay on. Never had it do this before. have turned off the switch and reset to 1 min vs 5 min, and it still stays on. any suggestions?
Here goes......First of all I Have the wireless model sensor.....I called heath and they replaced the sensor......Still did not work...Like you the flood lite stays on......I called them again and they said it could be the floodlite base. they told me to to send it back to the warrantee dept which I just did today.....
Feb 01, 2011 | Heath Zenith 270 Degree Replacement Motion...
I replaced the batteries in the motion sensor and now it appears that I need to learn how to adjust the timing. Is there a manual for the 270 (I think this is the one from the picture)?
there is a slide switch on the bottom of the sensor......test....1 min.....5min...
u may have to reset the sensor....turn power off .....then remove batteries.....wait 5 min....then turn on power....then replace batteries ......do not move the sensor and wait 1.5 minutes...
U can also call heath zenith @ 800 858-8501 and talk to tech support....
Jan 24, 2011 | Heath Zenith 270 Degree Replacement Motion...
My journeyman motion light just quit working for no reason. The bubls are good. As mention it was working fine then just stop working. What could be the problem?
The motion sensor unit shorted to due to rainwater infiltration, if its like the last half-dozen motion sensor units I opened up. Take the unit down, open up the sensor unit head, and if its got moisture inside, you know why it quit. If not moisture, then they sometimes do what all electronic devices eventually do, they fail due to 1 of the components reaching its failure - every sensor has an MTBF
(mean time between failure).
Jan 05, 2011 | Heath Zenith Journeyman 270 Degree Motion...
I have motion lightts on my back porch. I would like to just plain turn them on when I have a back yard party, but I don't know how to over ride the motion sensor. Can you help? Thanks.
On most motion sensor lights if you turn the switch on, then off and on quickly, they will stay on till you turn them back off. Leave it off for at least 10 seconds and turn it back on to go back to the motion sensor.
Sep 06, 2010 | Heath Zenith SL-6136-WH Basic Solutions...
Jan 19, 2010 | Heath Zenith 270 Degree Replacement Motion...
The light goes on at 3pm when I go into the sensor's path. I want it to go on at 8pm
This is listed under motion sensor. If so, there is no problem. If it's really a timer then:
Times have 3 components: Clock, two trip switches (on and off).
Make sure the mark you are using to set the clock is the correct mark and that you have AM PM correct.
Make sure you have the trip switches ON and OFF identified and set correctly.
Most appliance timers are pretty much alike. You should be able to walk into any appliance store and look at the directions for one like yours.
byron.armstrong.home@e-therapist.net
May 12, 2009 | Heath Zenith SL-6106-IV Motion Sensing...
Heath Zenith 270 Degree Replacement Motion Sensor - White, SL-5716-WH Logo
1,093 people viewed this question
Top Heath Zenith Home Security Experts
Mike
Domenico Grillo
Are you a Heath Zenith Home Security Expert? Answer questions, earn points and help others
