Hello, follow this link to download the manual and the codes for your remotes:
http://www.ofausa.com/remote.php?type=URC3220
just right click and save as on the download links.
if this does not work you can try the search method,
you do
this by either holding down the device button eg: TV or if you have one
the "magic" button for three seconds, a light should then flash twice
to say you have done this correctly.
then press the keys 991 then the power button.
you must now press the channel up key (ch+) possibly upto 150 times while the remote cycles through every code.
Once your tv or device switches off stop pressing the ch+ key and press the power button to make sure it switches back on,
(if you press ch+ too many times you can go back by pressing ch-)
When complete press the magic or device key again to save the settings (light should flash twice to confirm)
Many thanks
Mark
(www.sparky-uk.com)
SOURCE: program remote for direct tv receiver
Not a problem - here's a site that was built just for that problem. http://www.remotecodelist.com/remotes/
Simply scroll down through the list of remotes and locate the remote. Then click on the link to find a host of codes and procedures to program that remote for almost any device it's capable of operating.
Hope this helps!
Bill
SOURCE: Samsung (RS105N) Remote Control
Found the user manual here
http://www.directv.com/learn/pdf/System_Manuals/Samsung/Samsung_SIR300-310W.PDF
SOURCE: How do I program a Directv remote witha Samsung Directv receiver
http://www.directv.com/DTVAPP/global/contentPageIF.jsp?assetId=P4380052#h:1020.989
there is the website, put in the name of the receiver as Samsung and make sure you are under "SATELLITE SET TOP BOX" and follow the instructions on programming. hope this helps!
SOURCE: redi remote does not program
The Redi Remote has 35 buttons under a front sliding cover. The programming functions are under the sliding cover.
If you have any questions regarding Redi Remote operation, please call us at 1-800-REMOTES (736-6837)
