Model number WTW5000DW1 the part number is AP5988772
SOURCE: Remove lid of top loading washing machine Kenmore 110.92575110
Remove 2 screws that hold the console in place. Most are at the rear corners of the console. Pull console forward and up and tilt back.There are 2 brass clips holding the cabinet in place. then the cabinet can be removed by tilting forward and away from base. there is no reason to remove the lid.
SOURCE: Plastic handle Rival slow cooker model 38511 broken
The problem is the threads strip on the bolt and nut. I took these to Home Depot's specialty fastener section (the one with the drawers of stuff) and purchased a nylon bolt and nylon wing nut and solved the problem. I is easy to remove for cleaning and all is dishwasher safe.
SOURCE: 2002 camry - Need to replace broken console lid
Solved it. Found a small shank screwdriver that fitted into the opening with a little bending of the plastic frame. managed to replace it with a new one without trouble. No further help needed. dave
SOURCE: Whirlpool Cabrio WTW6600SW0. I need to replace the lid but ...
do you see about 2-4 inches down a crease that runs all the way around the top?
there are 2 clips in the front you need to push in with a putty knife and lift the whole top up.
if you where to look at the very left corner and go about 5-6 inches in you will find the clips.
can be a pain.
make sure when you do lift the whole top that you hold the lid or it will crash into something.
let me know if this helps
