Question about Viking 42 in Built In Professional Integrated Side by Side Refrigerator - VISB423
Viking side-by-side -- Condensation
Model # VCSB483D
The bottom of the freezer drips and leaks condensation from the gasket. The gasket has been replaced but has not resolved this.
Condensation persists and accumulates down onto our beautiful new solid wood floors.
We have to babysit the refrigerator daily, wiping the water around the gasket.
Note: My fridge does not seem to be on the recall list as the serial # indicates a manufacture date is 08/22/05, beyond the date of 03/01/05 on their recall list.
  • ucla89dolphi Aug 20, 2009
    Thank you SO much for this reply --
    I have since learned that the cause of the problem is the the freezer door does not close properly because the door is not aligned. It's further "inset" than the fridge door, but only at the top, making it kind of tweaked, does that make sense? The causes the gasket to become flattened at the top of the freezer and more normal at the bottom. I have had no less than 4 repair men through here making and "adjustment" to the hinge at the upper left (freezer) door. They all say that they cannot adjust it any further.
    (I mentioned a recall list because you can imagine how thrilled I was initially to learn that Viking was recalling my model of fridge because of a hinge problem --
    then I learned that it didn't apply to mine, and I have the correct hinge.)
    To summarize -- If you look at my unit, the top of the freezer door is pulled further in than the fridge. This distorts the gasket which doesn't "seal" properly.
    I feel like throwing this fridge out the window.
    I will do that next week when he comes back with (the latest gasket). I will def look at the defrost timer at the same time. Thank you! . . . More later.
  • 6,927 Answers
It really sounds like the defrost timer is staying on all the time.Have the timer checked.This must be a on going problem with this brand,I am getting a lot of them.So many things could be the problem,but the defrost timer is what really stands out,the defrost timer,does just that,it defrost only a certain short period of time,or it is supposed to.That is how you get frost free.If I can help any more please ask,but have the defrost imer checked ,or replaced.
Posted on Aug 20, 2009
  • Ronny Bennett Sr.
    Ronny Bennett Sr. Aug 20, 2009
    You may try and get a new gasket with a good magnet in it.Also have the defrost timer checked,I have a feeling,not to add to your problem already,but the defrost timer is not working correctly.
  • Ronny Bennett Sr.
    Good luck,I just think,it is too much water for condensation,but make sure ,if it is the tech,that he really test the defrost timer,and shows you,cause techs,can be decieving ,,
Frigidaire frost free upright freezer door corner dripping
Hello Yellow, thank you for your post!
I understand that your Frigidaire freezer is dripping water out of the corner of the door. It is possible that with your power going out the heat may have caused the gasket to warp. Do you see any frost build-up? The water that is dripping could be coming from condensation within the freezer. I would recommend checking the gasket to see if it is allowing warm air to enter the freezer.
I recommend that you visually inspect the door gasket for defects such as gaps or tears. You can also use a dollar bill to test the door gasket. Place a dollar bill in between the door and the body of the freezer. If the dollar bill pulls out with no to little resistance, you may need to replace the door gasket. A faulty door gasket can allow warm air to enter the compartment and cause frost to condensation or a leak. I hope this information is helpful. -Matt
Sep 01, 2015 | Frigidaire 13.7 cu. ft. / 388 liter...
Why would condensation be running down the sides,or water dripping from bottom?
should be a small plastic tray funnelling from under the fins in back to a small hole n hose out the back of unit check owners manual if possible,..
Jul 08, 2014 | Delfield Freezer 6125XL-S
My Admiral side by side has a leak from the bottom of my freezer.
check your door gasket for air leakage, it sounds like condensation.
Apr 01, 2014 | Admiral 26 cu. ft. Side-By-Side...
Fridge leaking
check door gaskets are in good condition Open and close door quickly Wait for maybe 10seconds and try and open the door . If the gaskets are working there will ne a marked resistance to opening
May 13, 2013 | Bosch KSU49630 Top Freezer Refrigerator
Appears to be the condensation leaking into freezer bottom and leaking all over the floor. Drain has been thawed but leaking continues. Local dealer advised to get a fix kit from viking, but I have no...
Drain troth kit with clasp to fix defrost drain port and to program board for conventional defrost to 4 hrs run time. Viking parts dist has that available 8004889868
Aug 26, 2011 | Viking VCBB363L Bottom Freezer...
Why is there condensation on the bottom of my freezer door
Condensation that wasnt present previously usually indicates a warm air leak into the cabinet. Check the freezer door gasket at the bottom for any malformations, rips, tears or gaps between the gasket and the cabinet face.
Sep 30, 2010 | Frigidaire FRS26ZSG
Water leaking from the front-bottom of the freezer drawer
A faulty door gasket will definitely cause excessive condensate and running time. There is also a door heating system which is from heated refrigerant circulating around the area where door gasket meets cabinet. You should be able to feel a certain amount of warmth in this area. If not there could be condensation again from cold leaking out of the gasket and being formed on the actual cabinet.
Mar 03, 2009 | Sub-Zero 650 / O Bottom Freezer...
Bottom of freezer has water dripping into it
A bad freezer door seal causes condensation that freezes at the bottom of the unit. I realize you said the drip pan was full of ice, but if the drain is clogged, that will happen. If that unit has the pan at the very bottom, condensation can also contribute to this.
Jun 17, 2008 | Maytag 25.6 cu. ft. Wide-By-Side...
Kssp42qhwoo(7 yrs old)
Check and make sure you defrost drain in the freezer isn't frozen. The water may be coming from the bottom of the freezer inside. When the heater comes on to defrost the evaporator, the water drips in to a small hole in the back bottom of the freezer inside. If the drain freezes, the water runs out into the freezer on the bottom and eventually onto the floor in front of the freezer door. It will eventually create a gap and let moisture into the freezer and may show up in the refrigerator section as condensation. Remove the ice build up including the alluminum drain pan area where the drain is located. Pour hot water into the drain to defrost it. You may have to remove the back of the freezer wall on the bottom to get better access. If the water goes down the drain, its clear. If you need a part for your refrigerator, please email me on ebay under user name themackshack. Good luck! , Mack
Jan 06, 2008 | KitchenAid KSSP42QKS Side by Side...
Viking 42 in Built In Professional Integrated Side by Side Refrigerator - VISB423 Logo
283 people viewed this question
Top Viking Refrigerators Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Viking Refrigerator Expert? Answer questions, earn points and help others
