Question about Dishwashers
KitchenAid dish washer: Control Panel Problem
I have a KitchenAid dish washer that suddenly the front control panel just stops working. I checked the power, checked the connection.. everything seemed ok. Any help ???
Thanks a lot
  • 75 Answers
Circuit board/ Electronic control assembly needs to be replaced.
Posted on Jul 24, 2009
Hi; Our washer displays "Control Panel
jazzbassic,
On the front of the unit is a control lock button, you will need to push and hold that button unit the control panel is unlocked. This should solve this problem. PS you may have pushed the control lock button when you either attempted to open door or just learned on panel, either way this does happen from time to time.
Jul 11, 2011 | KitchenAid KHWS01PMT Front Load Washer
Kitchenaid Dish Waher KUDI01ILBS1 won't run from control panel
Sounds like the control is bad. Turn off the power, remove the two screws at the bottom that secure the kick panel. Remove the kick panel and look under the machine for a folder up tech sheet. This will tell you how to get the machine into diagnostic mode. Follow the instructions exactly and it will help confirm whether it is the control.
Jan 15, 2010 | KitchenAid Washing Machines
Kitchenaid topload washer about 3 yrs old, started leaking from bottom, front. Checked hoses at faucet and washer, all tight no leaks there. Seem to be coming from under the front lower lip of washer.
it's the pump. release the control panel and flip back on hinges. pop the retainer clips and unplug the lid switch harness on top. pull entire white part of cabinet back and up..pump is front center.
Jun 14, 2009 | KitchenAid KAWS750L Top Load Washer
We own a Jenn-Air JDB7900. This morning the
More then likely the washer control panel has failed.
Apr 24, 2017 | Jenn-Air 24 in. JDB7900 Built-in...
Kitchenaid superba washer stopped working while in use. possibly timer. not sure how to remove timer box.
The timer knob on the front of the panel have to be removed. It unscrews, counterclockwise. If there are any plastic discs behind it, they will also have to be removed (by pulling off). This will expose the two screws which hold the timer in place.
If the timer knob doesn't unscrew and spins freely, the shaft leading into the timer is dislodged (permanently). You will have to destroy the timer to get to it. Remove the backplate by twisting straight the bent metal pieces which hold the cover in place. When you get to where you can see the shaft you will have to destroy the plastic which surrounds it to get to the shaft ifself. A pair of vice grips and a "I don't care if I destroy it" attitude is helpful. Once you get to the bare metal shaft you can hold it with vice grips and unscrew the knob to expose the two screws which hold the timer in place.
Jul 11, 2008 | KitchenAid Washing Machines
How to open washer to check for leaks
the two screws are on the control panel, one on each end. some are on the front and some are on the back. they hold the control panel to the case.
after you take those out then flip back the control panel (it has two hinges on the back so it wont fall).
then you will see the two metal clips, use a screwdriver to release the pressure and take them off.  you will immediately be able to remove the entire case from the front by tilting it back toward you.
or you can just lay the machine down on its side and look under it.
if the leak is coming from the front center then it is the water pump.
Jun 28, 2008 | KitchenAid KAWS850L Top Load Washer
Having a problem...
Have you try pressing the SAT button?
Feb 10, 2008 | DISH Network IR Remote Control
Diswasher stopped working
there is a fuse in the washer that needs to be replaced reply to me and will walk you through it
Dec 31, 2007 | KitchenAid 24 in. KUDI01FLSS Stainless...
Setting cycles and turning dishwasher on
Frenda Most likely the problem with your dish washer is shorted one or more pads on the key panel. To fix it the key panel has to be replaced. If you'll provide the complete model number and color for the control panel for your dish washer, I can help you to find the best deal on this part. Gendos
Jan 17, 2007 | KitchenAid 24 in. KUDG25SH Built-in...
Open Questions:
Brand new dishwasher will not finish washing, it just beeps and the lights flash red - CANDY CDP 1L39W/K I have a brand new Candy dishwasher model CDP 1L39W/K that won't finish it's wash cycle. When I do P5 for a fast 5minute cycle I hear the dishwasher fill up, it begins to wash, and then after it drains the water, then the dishwasher begins beeping repeatedly and flashing the red light under the P5 setting. When I check the detergent slot it hasn't been used yet. When I select a long wash like P3 the same thing happens after it drains the water, so I think the error occurs after the first rinse cycle? When I push down reset all the lights flash and then blink sequentially just like the dishwasher is waiting for a new cycle input, but the water pump to drain the water never turns off. If I push the power button the unit turns off but the water pump keeps running. Only when I disconnect the power cord from the wall will the pump turn off. If I reconnect the power cord the pump turns back on sometimes. I read online that maybe the flood switch was hit and to tilt the unit and drain water, I took off the kick panel and didn't see any water, and tilted the unit back and forth as instructed. The first time I tried this I think it may have helped the water pump turn off after I reconnected the power cord. But when I ran a cycle again nothing changed. I also waited a few days afterwards because I was busy at work enough time for any water to dry up but this didn't help. I'm in Vietnam and the customer support is Vietnamese so I thought I would try this before I have to see about the warranty and shipping the unit far north for repair. Any help is really appreciated, I can post a video of the beeping, blinking lights, and water pump running after I unplug the unit it'd help. I so badly want this dishwasher to just work, it was a big purchase here and a lot people don't understand why I'd buy it so now that it's not working it's really embarrassing! Thanks again!
Jan 22, 2018 | Candy Dishwashers
Dishwashers Logo
186 people viewed this question
Top Dishwashers Experts
