Cars & Trucks Logo
Colin P. Posted on Mar 29, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Sequence to torch water pump bolts on a 94 3.1Ltr. Buick century
I know my torch,but don't have the order to tighten bolts on 94 buick century 6 cyl.
Lawrence Oravetz
Level 3:
  • Buick Master 10,558 Answers
  • Posted on Mar 29, 2017
Lawrence Oravetz
Buick Master
Level 3:
Answers
10558
Questions
Helped
2695647
Points
29284
Tighten the long bolts first then the rest of the short bolts. A torque sequence isn't necessary for a water pump.
2helpful
2answers
Where is the waterpump located on the 1999 buick century
Hello, guys. I only found a article about how to replace water pump on a 2011 Buick century. Hope it can help you.
Also, there are lots of OBD2 diagnostic technical service for your refer.
How do you tighten waterpump pulley on 94' buick
How to Change a Water Pump on a 1994 Buick Park Avenue. ... Thread all the bolts onto the pump finger tight, then tighten the short bolts with your wrench in ... www.ehow.com/how_7471017_change-1994-buick-park-avenue.html
hope this will help
WHAT IS THE TORQUE ON A 94 BUICK CENTURY 3.1 V6 ON THE INTAKE AND EXHAUST PUSH RODS?
Tightening sequence would be to tighten from the center most bolts to the outer most bolts.
Intake Upper Bolts = 18 lb.ft.
Intake Lower Bolts = 10 lb.ft.
Exhaust Manifold Nut = 12 lb.ft
Exhaust Manifold pipe = 22 lb.ft.
Exhaust Manifold Heat Shield = 18 lb.in.
Rocker Arm Torque Nuts = 18 lb.ft.
Hope this helped you ?? if you need more info, get back to me.....
9helpful
Remove and replace the water pump buick rendezvou 2003 cost and do it yourself instructions . can i do it myself concerned with loosening the serpentine belt and needing special tools?
1. Drain the cooling system until the coolant is below the level of the water pump. 2. Remove the drive belt guard. 3. Loosen the water pump pulley bolts. 4. Remove the drive belt. 5. Remove the water pump pulley bolts. 6. Remove the water pump pulley. 7. Remove the water pump bolts. 8. Remove the water pump. 9. Remove the water pump gasket. 10. Clean the water pump mating surfaces. Installation Procedure 1. Install the water pump gasket. 2. Install the water pump Notice: Refer to Fastener Notice in Service Precautions. 3. Install the water pump bolts. Tighten the bolts to 10 Nm (89 inch lbs.). 4. Install the water pump pulley. 5. Install the water pump pulley bolts. 6. Install the drive belt. Tighten the water pump pulley bolts to 25 Nm (18 inch lbs.). 7. Install the drive belt guard. 8. Fill the cooling system
Visit my Blog here
10helpful
Need Cylinder head bolt torque specs and sequence for a 1997 buick regal V6 3.8 eng.
  1. Install the cylinder head gasket. Ensure the arrows point towards the front of the engine. The left cylinder head gasket has the letter L stamped next to the arrow.
  2. Notice
  3. This bolt is designed to permanently stretch when tightened. The correct part number fastener must be used to replace this type of fastener. Do not use a bolt that is stronger in this application. If the correct bolt is not used, the parts will not be tightened correctly. The system or the components may be damaged.
  4. Install the cylinder head.
  5. Install new cylinder head bolts. Tighten
    Tighten the cylinder head bolts to 50 N·m (37 lb ft) in sequence.
  6. Use the J 36660-A to rotate each cylinder head bolt 120 degrees in sequence. Use the J 36660-A to rotate the four center cylinder head bolts an additional 30 degrees in sequence. Refer to Notice Use the correct fastener in the correct location. Replacement fasteners must be the correct part number for that application. Fasteners requiring replacement or fasteners requiring the use of thread locking compound or sealant are identified in the service procedure. Do not use paints, lubricants, or corrosion inhibitors on fasteners or fastener joint surfaces unless specified. These coatings affect fastener torque and joint clamping force and may damage the fastener. Use the correct tightening sequence and specifications when installing fasteners in order to avoid damage to parts and systems.
92 buick century head bolt tighten sequence?also head bolt torque?also manifold? 3.3l v6 engine thanks
Exhuast manifold torque 38 foot pounds, Head bolts are 38 Foot pounds after you add sealant to the bolts then after torque go another 130 degrees. Tighten center 4 bolts in sequence another 30 degrees. 0b61846.jpg
Distributor firing off sequence need f order.
Buick Regal, Century, Chevrolet Impala, Lumina -- General Engine Specifications 1999-01 ... 3.1L Engine Firing order: 1-2-3-4-5-6 Distributorless ignition system
24helpful
How to change a water pump on a 1999 Buick Century 3100?
the water pump on the 3.1 isnt to hard to change ...
  1. Disconnect the negative battery cable.
  2. Partially drain the cooling system into a suitable container.
  3. Remove the drive belt guard.
  4. Loosen the water pump pulley bolts before removing the drive belt. This should help keep the pulley from turning as the bolts are loosened.
  5. Remove the drive belt. Remove the water pump pulley bolts and remove the pulley.
  6. Remove the water pump bolts and separate the pump from the engine front cover.
Top Buick Experts
ZJ Limited
ZJ Limited
Ronny Bennett Sr.
Ronny Bennett Sr.
Thomas Perkins
Thomas Perkins
Are you a Buick Expert? Answer questions, earn points and help others
