After copying, original creation time and dateseems lost, only have copy time and date. Where in the metadata is the original data?
SOURCE: Cannot copy large video files from Canon Powershot s515 to computer...
Get a USB flash card reader, and read directly from the memory card into your PC.
SOURCE: Canon SD870 - Unable to copy AVI files to desktop
You need video editing software to copy .avi files to.
XP and Vista have that onboard.
Either direct the data to it or import the data from the individual program.
If that does not work, then you have a transfer problem between Camera and PC.
Try a card reader, that will prove it.
SOURCE: Lost my Canon PowerShot G9 Digital Camera Solution CD-ROM
All related software for ur camera See drivers and download section
Here
Pls rate me WELL !
SOURCE: canon G10, clicking noise when turning camera on
Hello
The problem is that the lens has become stuck in the barrel. There are some DIY solutions you could try, but the
probability is that you will have to get it fixed by a professional.
Use
these at own risk as it may further damage the camera.
Firstly ,
try connecting your ac adapter or usb cable.
Try holding the
shutter button while switching on the camera.
Look at the lens ,
and if some of the lens 'circles' is misaligned or not concentric then
try wiggling it (while holding camera lens down).
Try gently
pushing or pulling the lens when it extends but this is risky as it may
cause the lens barrel to slip out of its guidance system.
Another
way to do this is to place the camera lens down on a hard surface and
then power it up. Be sure to use a soft cloth or something similar as to
not scratch your lens or casing. Let the lens push the camera up and
down a few times and sometimes the little resistance provided by the
camera is enough to get things going again.
Try hitting your
camera near the lens on the body with the soft tissue on the palm of
your hand.
Other than that , I would take the camera to a repair
center for a evaluation to see if it would cost more to repair than to
replace the camera.
If it is still under warranty I would suggest
you take it in before trying any of these steps and remove any
off-brand batteries or accessories as some stores are really fussy about
warranty repairs on camera's with non-brand accessories.
You can also have a look at THIS link.
Hope
the advise is useful. please do not hesitate to let me know if you need any further assistance.
Regards
Andrea
SOURCE: I can copy the files from my Canon DC220 camcorder
You can use VLC player, to play this movie file. It supports most of video extensions that can't be played by other media players. For downloading the software you can visit this link: http://www.videolan.org/vlc/
