Question about Lincoln Electric LINK2400-+2 CV-305 MIG Welder with Options Input Power: 23
The wire feed on my welder will not work.
I have an sp 200 idea arc Lincoln mig welder. The wire feed will not work. When in weld mode, no electricity is reaching the 24 volt electric motor on the feeder. Also no electricity is coming out of the negative or positive leads. It has 220 volts going into the transformers when in weld mode. Can anyone help me out on this. thank you, Dale.
  • lee coleman Feb 04, 2012
    i am having the same issue with my idealarc sp-200 did you figure out what was wrong?
    lee
Maybe you can get lucky like I did . Some times the acr volt selector switch gets corrosion in it and wont let the circuit board know to send power to the wire feed motor. You can cycle this arc volt. switch in my case it is the a,b,c,d,e, switch back and fourth a few times and this will brake the corrosion and your wire might feed again as mine did . This corrosion build up happens from not using and or sollecting the switch much usually on a welder at hm that gets very little use. it is common good luck .
Posted on Apr 18, 2013
  • Dwayne McCloud Sep 03, 2013
    simbaom. Thanks for the advice. I have a Linclon SP130T and the feed motor quit working. I was looking at buying a new one due to its age. After reading your reccomendation. I cycled the arc volt switch and it went back to working. This is the first problem i have had with it in almost 20 years i have had it. It is a great unit
  • Cesar Rios
    Cesar Rios Aug 01, 2014
    Dude, best advise ever! I was frustrated with my 140 hd I've had it for 2 short years and the feed quit on me. I tried the selector switch and viola! Thanks you saved me a bunch of dough. I even tried Lincoln pros and they sent me on a run. Thanks
    Problem Solver:
  • 5 Answers
Dale,
Probably the trigger/ open the lead and try to short the connections for the trigger by bypassing the trigger acuator. This is the mechanism that activates the wire feed motor and applies the welding voltage to the wire. If this works, get a new torch handle.
Posted on Jul 25, 2009
What make & model mig gun is fitted to this machine
Mig Guns & Mig Gun Spares - The Welders Warehouse
www.thewelderswarehouse.com/Welding/Mig-Welder-Gun.html
We have Mig Guns and spares to suit a wide range of Mig Welders. ... Torches are usually Euro Fitting and are typically fitted to professional mig welding machines of ... attitudes from people one is giving money to ! its great to get good service.
[PDF]POWER MIG ®(140, 180 MODELS) - Lincoln Electric
www.lincolnelectric.com/assets/...public/.../im890.pdf
Lincoln Electricshipment must be made by the purchaser against the transportation company at the time the shipment is received. SAFETY DEPENDS ON YOU. Lincoln arc welding and cutting equipment is designed and built with ... properly fitted and with proper grade of filter plate .... Semiautomatic DC Constant Voltage (Wire) Welder.
Millermatic® 211 MIG Welder - MillerWelds
Dec 20, 2015 | Welding Tools
Porblem with lincoln mig welder 135
Use a voltage tester to make certain you have current at the steel roller assembly that the wire feeds through. Check the diameter of the wire also, to assure contact at the feed rollers.
Mar 18, 2012 | Lincoln Electric Welding Tools
I have a lincoln sp-175plus, when trying to weld it the arc just melts the wire and it balls up at the end. I also put a new contact tip in. As well sometimes the wire feed just stops. I then press...
Your drive tension is too light. There are rollers that the wire feeds through and they need to be tightened. They should push the wire through the gun but slip if you put the tip against a solid object and pull the trigger. If they do not slip, they will jam your gun. Give the tensioner another turn.
Jan 08, 2011 | Lincoln Electric LE 83180 Century...
Weld arc not stable. Wire feeds, good ground,
Arc blow could be the cause! Put your ground on the work piece and weld away from it. If you weld toward a ground clamp the magnetic forces will blow your arc around sometime. When taking a cert this simple mistake can make or break ya on your cap or reinforcement beads.
May 09, 2010 | Hobart Handler 140 Mig Welder
I have a craftman mig 110v mig welder arc problem
Check to make sure the contact is not touching the nozzle of the mig welder. This would definitely short it out!
Apr 14, 2010 | Lincoln Welding Tools
Where can i buy a new switch for a Lincoln MIG welder CV-305
From your local Lincoln welding supplier or lincoln direct.
Nov 28, 2009 | Lincoln Electric LE 83180 Century...
Mig Question
MIG stands for Metal Inert Gas welding, many times called Wire-feed.. Also referred as GMAW (Gas Metal Arc Welding). The "Metal" refers to the wire which is what is used to start the arc. It is shielded by inert gas and the feeding wire also acts as the filler rod. A semi-automatic process, it is fairly easy to learn and use.
Aug 27, 2008 | Lincoln Electric LINK2400-+1 CV-305 MIG...
Lincoln Electric LINK2400-+2 CV-305 MIG Welder with Options Input Power: 23 Logo
2,334 people viewed this question
Top Lincoln Welding Tools Experts
Steve
joe2639
Level 1 Expert
Are you a Lincoln Welding Tool Expert? Answer questions, earn points and help others
