Question about Schumacher & Fast Charge Starter Charger
SCHUMACHER 2/10/50 CHARGER NOT SEEMING TO WORK MAKING NOISE BUT NO READOUT ....
Take 4 screws out, take cover off be easy, and there is a blue wire on right side that go's around the back to left side, circuit board mounted on the left side. on the top of board towards the back of charger, there are two pins. that the blue wire connects to. The reason the blue wire "connector" came unplugged, is because of the handle on the top. when pushed down hits the wire "connector" knocks it off.
Posted on Sep 19, 2009
2 Suggested Answers
  • 152 Answers
SOURCE: Schumacher 2/10/50 amp charger,125/225 amp starter
It could be an internal fuse, or that the transformer is malfunctioning.
Before any dis-assembly/internal inspection, be sure that the unit in unplugged.
Good luck...
Posted on Feb 25, 2009
Schumacher charger
Are you sure the connectors are making a good connection to the cable out of the charger?
Sep 23, 2016 | Schumacher Electrical Supplies
How do I open a SC-600A Schumacher battery charger to repair it?
Unfortunately I have the same question. I have removed two screws, but no parts can be pulled off.
The person who wrote the following article apparently knows how to open the charger box.
https://wizbandit.wordpress.com/2008/08/12/hacking-the-schumacher-speed-charge-for-phev-ev-use/
Aug 12, 2015 | Jensen Schumacher SC-600A SpeedCharge High...
Manaul for schumacher battery charger model se4020
Your battery charger supplier or manufacturer should be able to supply you with an operating manual.
Aug 14, 2014 | 10/40/200 Amp 6/12-Volt Manual Battery...
Can I use a 3amp smart charger (new) on a 2003 CLK
I would suggest directly to battery, but any charger will work. Just make sure it cycles before leaving it (on and off). A timer on the switch might be a good idea just in case.
Apr 13, 2010 | 2003 Mercedes-Benz CLK-Class
Lost the wall charger of my Schumacher 400w power inverter (model PP-2200), where can I get another one?
Ah, I see, it seems what you have is a power pack. If so it would contain a gelcell battery, probably 12 volts. If this is true, then you may charge it with any 14-16 volt wall charger. You have to make sure you observe correct voltage and correct polarity when connecting up. Also you may have to obtain and change the plug on the charger wire.
I'm assuming the battery DC output is inverted to AC and you use it to power small AC appliances.
Mar 21, 2010 | Schumacher 400w Power Inverter
Why is it making a humming noise
If it is humming ONLY when you connect it for charging and does not hum when you have no load on it...it has too much initial load and the humming is caused by an output current overload.
I don't know what you are trying to charge....if you are VERY careful and you can monitor the output current load....you may be able to get a charge....BUT BE VERY CAREFUL!
Mar 09, 2010 | Schumacher & Fast Charge Starter Charger
Schumacher & Fast Charge Starter Charger  Logo
1,024 people viewed this question
Top Schumacher Electrical Supplies Experts
D. E. Hev
Lawrence Oravetz
Are you a Schumacher Electrical Supply Expert? Answer questions, earn points and help others
