Question about Black & Decker 18 - Volt Pole Pruning Saw
Battery fully charged but pole prunning saw does not work at all poles are connected properly
5 Suggested Answers
  • 25 Answers
SOURCE: Hello! I have a Black
You need to know the size pitch and brand of the chain. See if it has a name on it anywhere. It may have a pitch # stamped on the side. My remington uses a Oregon chain.
Check the chains at walmart and see if they look the same. You may find a cross ref on the package that will give you another part#
Another option is to replace the bar and chain with a new Oregon Replacement Bar & Chain Combo kit.
See this site for examples.
try this cross ref chart
Posted on Jan 14, 2009
dontbother10
  • 2220 Answers
SOURCE: lost maintainance instructions for NNP 2018 pole
It sounds as though you have bent drive links? I would probably replace the chain. Burrs we can help, see Chain Repair here:
http://www.fixya.com/support/r4146814-chainsaw_chain_installation
The instruction sheet is available here:
Black & Decker
Go To “ServiceNet/” link
Bottom of center column “Need a Manual?” Enter model number, “YourModel” in window.
If you have more questions or need additional help please reply below and I will get back to you. Thank you for using FixYa and Good Luck. HTH
Lou
Posted on Mar 02, 2010
wentlanv
  • 710 Answers
SOURCE: I have a B &
The chain is part #623382 00 and can be purchased at toolpartsdirect.com for one place. I like this place as they ship quickly and aren't overpriced.
Use a 5/32" sized-file to sharpen the chain at 30°.
The correct size chain is a 3/8" pitch, gauge 0.043.
The brand Oregon offers these chains also. You might find one at your local outdoor equipment place or chainsaw place.
Hope this helps. If it does, I'd appreciate your vote. Thanks,
Handie Andie
Posted on Jun 05, 2011
  • 10865 Answers
SOURCE: B&D pole chain saw- just
hello needa.... I agree.....everyone needs a vette.... now to the chain saw. generally when this occurs the chain is too tight. The fix is to lube the chain and reduce the tension on the chain. Joe
Posted on Jul 10, 2011
Black and decker pole saw. Fully charged battery, brand new chain installed correctly. It appears to lack enough power to cut.
Make sure the chain tension is set correctly.. If it's too tight it won't be able to pull it round the bar..
May 23, 2016 | Garden
Black decker problems
Either the switch is defective or the wire inside the pole is broken
Jun 02, 2014 | Black and Decker USA Black & Decker 20v...
Electric pole saw was put togeather wrong and can't take pole apart.
check for a small button in the connecting parts of the pole press it in and slip the parts
on reassembly make sure that that button lines up with a hole and clicks in
Sep 16, 2012 | Earthwise 10" Cordless Lithium Pole Saw
How do I put the saw on the pole
1. Remove battery from chain saw.
2. Separate main handle from chain saw
power head by pressing both release
buttons on main handle and pulling
apart. The release buttons are just in
front of the trigger.
3. Align rib on chain saw power head with
groove in power head adapter on pole.
4. Slide power head into power head
adapter until units "snap" together.
IMPORTANT: Both release
buttons on power head adapter must be
fully engaged.
5. Align rib on handle adapter on pole
with groove in main handle.
6. Slide main handle into handle adapter
IMPORTANT: Both release buttons
on main handle must be fully
engaged.
7. Slide battery onto main handle until
release buttons "snap" together.
Be sure the battery is charged.
To extend the pole:
1. Loosen the clamping
lever. Pole will slide
freely.
2. Pull inner pole section out to desired
length of extension.
3. To lock pole in position, tighten clamping
lever.
Sep 12, 2011 | Remington Cordless 18-Volt 8-Inch Cordless...
I have a RYOBI pole saw that starts fine, but there is a disconnect between engine and saw blade. The blade will not turn.
I assume you have the Ryobi powerhead with the multiple tool shaft (can use it with an edger, blower, trimmer, and pole saw) If so, does the powerhead square drive spin when you squeeze the throttle trigger? Does the chain move freely on the saw end when not connected? Is the attachment fully inserted into the powerhead shaft (small spring-loaded button should pop out of the hole when fully inserted.
Aug 26, 2011 | Garden
I need an oil cap for my pole saw 108526-01
An IPL (exploded parts list) for your pole saw can be found here: (I recommend you save a copy)
http://shoppingcart.msservicecompany.com/msservice_net/product_files/RPS96/RPS96_BD.pdf
Page 2 Item 8 pn 107512-01 $3.98
Can be ordered here:
http://www.desaparts.com/index.htm
The model you provided enabled me to fully answer your question. Atta boy/girl. Thanks
Lou
Sep 29, 2009 | Remington Electric Pole Saw
Have pole with 8inch saw and will it work for 14in saw
If you have a Remington pole saw, then no you cannot not get a bigger saw to fit the pole you have. The pole was only designed to fit and support the weight of the saw it came with.
Apr 23, 2009 | Remington Polesaw Wizard
Remington Pole Saw
LOOK UP ( PARTS FOR.COM ) FOR THE TRIGGER SWITCH
Jul 04, 2008 | Remington Polesaw Wizard
Black & Decker 18 - Volt Pole Pruning Saw Logo
44 people viewed this question
Top Black & Decker Garden Experts
Nick Olsen
Roland W VanLue
Roland W VanLue
Tim Whalen
Are you a Black & Decker Garden Expert? Answer questions, earn points and help others
