Question about Canon PIXMA MP530 All-In-One InkJet Printer
MP530 printing a black line on the bottom of page I print.
How do you correct this problem.?
After reading the instructions for taking the printer apart from top to bottom (where the absorber is), we opted to follow someone else's advice for a quick fix. We turned the printer upside down and used a box cutter to cut a trap door in the center of the bottom, pulled out the absorber, replaced it with an equivalent sized rectangle of printer's cotton, and taped the door shut. It has been working fine for several months now.
Posted on Mar 04, 2012
    President:
  • 2,306 Answers
If the black line is on the back of pages, your machine needs to be taken apart and cleaned, a new absorber installed, and a mylar shield added so that this doesn't happen again...
Posted on Jul 24, 2009
Solid black ink line, top to bottom, on back of every printed page
The possibility of the printer roller is dirty. To clean the roller, do
1. Press the START
2. Select Printers and Faxes
3. Right click Canon PIXMA MP530, select Printing Preferences
4. Select Maintenance
5. Select Roller cleaning, and Bottom plate cleaning
Nov 02, 2011 | Canon PIXMA MP530 All-In-One InkJet...
Printing
No black line while you scan, but it only appears while you are printing?
Mar 18, 2008 | Canon PIXMA MP530 All-In-One InkJet...
Can you do macs? how do i print duplex with this printer, duplex is suported by my mac
The Canon-supplied MP530 driver doesn't have duplex printing as a print option. Mac OS 10.5 has Gutenprint drivers built-in for a number of popular printers, including the Canon MP500 which is a near match for the MP530 and includes the two-sided option for printing.
With the MP530 plugged into your Mac (or, presumably, available over the network) go to the Add Printer wizard ( System Preferences > Print & Fax > + ). Pick MP530, name the printer something like "MP530 Gutenprint" and under "Print Using:" choose "Select a driver to use...", select "Canon PIXMA MP500 - Gutenprint v5.1.3" and then Add the printer.
The MP500 Gutenprint driver isn't a perfect substitute for the MP530 one, however, so you should do this in addition to installing the proper MP530 driver from the Canon website and adding the printer using that driver with a name like just "MP530" or "MP530 Canon". In a year or two of using the Gutenprint driver I've only once had a print job that wouldn't render correctly (some missing lines on the printout), and for that one time I had to switch to the Canon-supplied driver to get it to work. All the other times I find it very convenient to have two-sided printing available as an option.
The two sided printing isn't particularly fast, but it's a whole lot more convenient than manually printing the odd pages and then the even pages.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
Mar 28, 2011 | Canon PIXMA MP530 All-In-One InkJet...
Ink leak?
It's not the cartridges, the waste ink is coming up thru the bottom to the exit rollers. The only fix is to have a shop open it up, clean up the ink mess and install a shield that stops the ink from coming back up when it should go to the absorbers. The new machines all have this shield and the ink tube cut back to make the ink go where it should.
Feb 21, 2010 | Canon PIXMA MP530 All-In-One InkJet...
My Canon MP530 keeps printing a thick black line on the backside of every page that i print. any suggestions
try to check and change the usb cable and if it does not solve it uninstall the installation of the of the printer and reinstall it again
Jan 17, 2010 | Canon PIXMA MP530 All-In-One InkJet...
I have a mp530, and when the large black is out of ink, it wont print. It has a second black cartridge, but it seems as if that is never used and not needed. What is wrong? Why have 2 black cartridges if...
Printer use big PGI-5 black cartridge have pigment ink for printing text, documents or other only black pages.The little CLI-8 cartridge have dye-based ink for printing photos and other color pages.You need to replace your PGI-5 black cartridges to continue printing.
Nov 16, 2009 | Canon PIXMA® MP530 All-In-One Printer
Band of ink on back of printed page
The exit rollers need to be cleaned, but whats happening is ink is coming from the bottom onto the rollers. It needs to come apart and be cleaned and a mylar strip put in to keep the ink from coming up. A shop repair usually.
Jul 14, 2009 | Canon PIXMA MP530 All-In-One InkJet...
Thick black line printing on the back of every page
your printer needs to be serviced and check printer alingnment
May 21, 2009 | Canon PIXMA MP530 All-In-One InkJet...
Thick black line on printed page
If the line runs the way that the paper does I.E. vertical on a portrait then it is dirty rollers normally.
If you open the lid and wipe the rollers this shoukd reduce or eliminate the black lines.
May 03, 2009 | Canon PIXMA® MP530 All-In-One Printer
Black Line on back of pages
Your problem is not isolated; I read of two others on this site in mid-August 2008 and added my own post.
I contacted Canon Support and tried their solution (which you've already tried); it did not work. Given the choice of repairing a printer that I've had (and babied) for less than 2 years or buying a new Canon at a discount under their Loyalty Program, I chose to take my MP530 to a Canon Authorized Repair Facility.
According to the repair tech, there is a problem with the waste ink tank and ink absorber pads. The repair facility ordered and installed a rebuild kit; it took about 2 weeks. The printer now works beautifully again.
If your printer is still under warranty, you're in luck. If not, ask that it be handled as a warranty repair. In my opinion, Canon should recalling and offering to fix this problem free of charge.
Aug 18, 2008 | Canon PIXMA MP530 All-In-One InkJet...
Canon PIXMA  MP530 All-In-One InkJet Printer Logo
185 people viewed this question
old marine
old marine
