Home Logo
S
Shirley Petty Posted on Mar 29, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Wall clock Ptrausboury Manor chimes on half hour instead of hour. How do I fix it?
Lisa Lannom
Level 2:
Passionate:
Visited the website for 10 consecutive days.
Habit-Forming:
  • Expert 32 Answers
  • Posted on Apr 02, 2017
Lisa Lannom
Expert
Level 2:
Passionate:
Habit-Forming:
Answers
32
Questions
Helped
11732
Points
104
Try to carefully remove the MINUTE hand (not the hour hand, as posted previously!) entirely from the clock then put it back in the "proper" place. for example, when it strikes at the six, remove the minute hand and put it back on pointing at the 12. Then re-set the time for half-past (or maybe quarter-till the hour by now! lol)
Seth Thomas wall clock doesn't chime on the quarter, half or three quarter hour but does chime on the hour
Please change the time of your wall clock back 1 hour and check if the other 3 chimes return. There should be knobs on the side of the clock to help you do this. If not on the side, then please check on the back. Since you've already checked the settings and ruled them out as the cause of the issue (as well as the batteries), you might need to perform a factory reset on the clock if the steps I mentioned above fail.
Thank you.
Strausbourg manor quartz Westminster mantel clock. Why did it stop chiming?
Source: Wikipedia
The full hour chime is followed by one strike for the number of the hour by Big Ben (E3) (one strike for one o'clock, two strikes for two o'clock, and so on). ... The mechanism then plays two complete sets of five sequences for each complete hour.
Source: PortableFireplace
Learn how to fix a mantel clock that chimes at the wrong hour. This simple fix will repair a clock that chimes at the wrong time. This can commonly occur when your mantel clock is laid down on its back and the timing is offset.
1 Thing You Have to Understand First On most clocks you can turn the minute hand counter-clockwise but SOME clocks are not safe to be turned in that direction. For this reason, it's best to only turn your minute hand clockwise just to be safe.
The Simple Mantel Clock Adjustment The easiest way to adjust a mantel clock chime is to move the hour hand to the hour that the chime is striking. Make sure that the hour hand shaft is not too tight or else it will not turn. Most mantel clock hands are friction held. DO NOT BEND YOUR HOUR HAND, loosen the shaft if it will not turn freely.
Once you have synchronized the hour hand with the hourly chime, adjust the minute hand to set the clock to the correct time by moving it forward (clockwise) around the clock face. Allow the chime to strike at every quarter hour strike.
Mantel clock Chime Adjustment When your mantel clock chimes the wrong number of times, your chime is not synchronized time of the clock. To adjust your mantel clock chime, proceed with the following step:
ADJUSTING THE HOURLY CHIME
  1. When your mantel clock chimes, count the number of times it chimes. This is what time your hourly striker is set to.
  2. Move the hour hand to the hour indicated by the hourly chime (count the number of gongs at the hour).
  3. Reset the time using the minute hand to the correct hour and the chime should adjust along with the clock hands as well.
ADJUSTING THE QUARTER CHIME
On most mantel clocks, you can simple remove the minute hand which is friction fit. You have to apply pressure on the tube and it will loosen. Once removed, re-install the minute hand at the correct time. From there you can rotate the minute hand to reset the time.
Mar 17, 2021 • Home
1helpful
The chimes will not chime on the quarter hour and half hour - just the full hours. This happened after we set the clock back for daylight saving time. How can I correct this?
The clock probably thinks its night / early morning so it stopped chiming on the quarter hour. Move the clock forward 12 hours. It should correct itself to think its day time instead of morning.
Oct 29, 2018 • Home
How do you fix chime on hour instead of on half hour?
Hello Shirley Petty,
Because you specified no movement name,
make or model...
I'm going to assign myself the simplest movement
on this precious little planet...
The battery operated $82 pendulum
with GENUINE electronic chimes:
https://www.klockit.com/tubular-quad-chime-quartz-clock-movement.html
Solution:
REPOSITION those HANDs
to match
the chime strokes.
(boom)
Carnac the Magnificent
Mar 26, 2017 • Chime Home
How to set a classic manor quartz west minister wall clock to chime at the correct time.
Hello Fern Hicks,
Short of ORDERING IN A NEW movement I
would rather try removing the hands... and placing them where they are chime appropriate...
I'm sure there are more convoluted ways of accomplishing the same thing... but I so old & clock oriented... I only turn clocks & timers in the FORWARD direction (very OLD school).
Remove the minutes hand (from where-ever it strikes)...
Move the hour hand (only if necessary & replace the minute hand as appropriate to the movement strike.
Classic Manor Quartz Westminster Chime Pendulum Clock0 results You may...
The clock chimes right on the hour and used to chime once on the half. Now it chimes the number on the half instead of once.Need just chime once on the half
The next time it gongs multiple times turn the hour hand clockwise until it is pointing at the number of times it gonged. Next take off the dial nut off (make sure to put it in a plastic bag because they can be hard to replace) and turn the minute hand until it strikes once. Now put the minute hand back on pointing to 6 o'clock and replace your dial nut and you are all set.
Fix Clock That Gongs Wrong
Feb 26, 2016 • Home
My wm widdop clock chiming out of sequence
The next time it chimes multiple times turn the hour hand clockwise until it is pointing at the number of times it gonged. Next take off the dial nut off (make sure to put it in a plastic bag because they can be hard to replace) and turn the minute hand until it chimes signaling 15 minutes after. Now put the minute hand back on pointing to 3 o'clock and replace your dial nut and you are all set.
Oct 21, 2014 • Home
5helpful
3answers
Strausbourg Manor Wall Clock chime adjustment
It is normal for the average wall clock. Of course, this can be adjusted, but without watch/clockmaking knowledge it is impossible, because first you need to find out which part of the movement is causing early chiming - and there are plenty of them.
Super fine adjustment can be found only in top of the range clocks. Hundreds of hours of craftsmenship are spent to adjust and fine tune them. That's why they cost a fortune.
If you can not live with that early chiming, you have to bring your clock down to the watch/clock repair shop and ask for help. Be ready to pay quite a money, as this job takes the skill and a lot of time.
Rate me, please.
Syncronize chime strokes to clock
Top Home Experts
john h
ADMIN Andrew
ADMIN Andrew
Are you a Home Expert? Answer questions, earn points and help others
