Pls Check oil drain solenoid it's may need to rebuild or replace.If solenoid is OK then you may need to change oil drain switch.
SOURCE: 34700z resetting filter weight
Check ISV tank liquid & vaipor hose.make sure it is not too much tight or lose. also check recovery,recycle & oil return solenoid are opening properly.
SOURCE: NEED TO CHANGE FILTER IN
There is a site www.nytechsupply.com you can down load a pdf manual free of charge. it will have the
instructions and any thing pertaing to your recycling machine. good luck!
For change vacuum pump oil follow the bellow step: Press main
menu then keep pressing up or down arrow key till display show "CHANGE VACUUM OIL" then press "YES" key. Now vacuum pump will
run for two minute & stop automatically. When pump stop you just open the
oil drain cap and drain all used oil from pump (oil drain cap located outside
of the machine near high & low side hose). After draining all used oil replace
oil drain cap and fill 5 ounce new ROBINAIR vacuum pump oil then press "YES" key and keep filling oil up to middle of sight glass of vacuum
pump. Press "STOP" key to complete the process.
NOTE: Do not over fill the pump & do not use any COMPRESSOR oil on the vacuum pump!
Hope this will help you & if it is please vote for my support.
Hope this will help you. If
so please vote for it. Good luck
