Question about Whirlpool 21.0 cu. ft. Top Freezer Refrigerator with IceMagic Plus Ice Maker
I have the same problem
My model number is GS5SSHAXNQ00
Type: 26ssa
The sound is coming from the right side of the door where the door switch is located. Is there a way to change the switch?
    Scholar:
  • 117 Answers
Yes it is a simple depression contact switch that pops out . Sometimes with the gentle help of a screwdriver. Install is same in reverse.
Posted on Jul 24, 2009
What is the solenoid valve behind the door face plate wr55x10001 call
PULL OUT THE ICE BIN AND HEAT UP THE BACK IN SIDE THE FREEZER,YOU'LL SEE A HOLE ON THE RIGHT SIDE BACK THERE THIS IS THE SOLENOID THE SWITCHES IT FROM CUBED TO CRUSHED ICE IF THAT GETS FROZEN IT WILL HUM, WHAT PROBLEM ARE YOU HAVINGTHEN HOLD THE DOOR SWITCH IN AND HAVE SOMEONE PUSH ON THE PAD WHERE YOU DISPENSE THE ICE AND SEE IF THAT FREES IT UP,also that model number doesn't come up,open the fresh food door,look up on the right side wall near the ceiling and you should see a tag with model and serial number
Oct 14, 2014 | GE Profile TPX24PBDCC Side by Side...
How do I turn demo mode off on FGHS2631SS Frigidaire?
Are you sure you have the right model #? Your refrigerator's model number may vary by type. The model number of a top freezer refrigerator can be seen along the upper left side wall of the fresh food compartment and is visible when the door is opened. The model number of a french door and side-by-side refrigerator can be seen along the upper right side of the fresh food compartment and is visible when the door is opened. model-number-refrigerators.png
Sep 10, 2014 | Refrigerators
I have a Whirlpool Gold Ultimate II dryer. When the door is opened on the dryer, the light does not come on and the clothes do not stop spinning. I think there is something wrong w/ the swich inside the...
This video will show you step by step how to replace the door switch It does indeed sound to me as well that your stop on and the door switch is the problem
GENE
Sep 05, 2011 | Dryers
I have a GE Profile "Artica" side-by-side refrigerator model PSC23MGNA - BB. Recently the refrigerator door has begun swinging all the way open ... 180 degrees ... and banging into the...
if you look down at the bottom of the freezer door you'll see a door stop,two 5/16 inch screws hold it in place,the stop on the fridge door must of broke.you can switch it from the freezer to the fridge door for now until you get a new one.part number is WR02X13425 and it's around 5 dollars.give your parts store the model number and they will take care of you,or go here,pick any topic here,put your model number in,to the right of the model it will as model or part number,pick model and click on it and your machine will come up,click on fresh food door,your part is numer 12 and you can order it from sears if you want.let me know how you make out
Feb 02, 2011 | GE (PSS26MSRSS) Side by Side Refrigerator
Will not spin correctly , slow spin
open the door,remove the screws that hold the door on and the two screws accross from them,pull off the front panel gut keep the door on.now remove the two L brackets that hold the top on,lift up the top.put the machine in the spin cycle and see if the wax motor is pushing the plunger all the way over to make contact with the micro switch,the lock door light will lite and then a few seconds after the plunger should hit the switch,if it doesn't push the black plastic button piece in on the switch a few times and listen for a clicking sound.if it's clicking put it back into spin and after the door lock light comes on push the black button in and hold it in to see if it spins in high spin,if it does change out the micro switch.or with a meter put the tester wires on the clips that the wires slide onto and push the button in and out and see if it opens and closes,if it checks good and it spins on high spin when you push the black button in then you have a bad wax motor,it's not pushing the plunger over all the way.if both parts are good then you have a bad inertial switch.it's on the right side of the tub,you have to pop off the right side boot seal and remove the screws that hold the right side of the front shroud in place,pull the right side of the shroud out so you can get your hand in there to remove the inertial switch and change it out. part number 22003302.it's around 40 dollars.i couldn't find the micro switch or the wax motor but you can give the parts store the model number and they will help you out.a few times it was the micro switch so i would start there.let me know how you make out
Jan 22, 2011 | Maytag Neptune MAH5500B Front Load Washer
Kenmore 12502100 won't cmplete rinse cycle
This is a typical symptom of a lid switch problem. If you open and close the lid, you should hear a "clicking" sound as the lid switch is activated. If you do not hear the switch, check to make sure the lid strike in still intact. This is a small plastic piece mounted on the lid that pushes down on the switch through a slot on the wash tub opening on the right hand side. If this piece breaks off, it will give the same symptoms of a broken lid switch. Next, check the two mounting screws on the right side of the wash tub opening to make sure they are tight. These are the mounting screws for the lid switch. Sometimes they come loose and the switch does not make proper contact. If you attempt all these preliminaries, and the switch still does not seem to be working properly, replace it. A replacement can be found at searspartsdirect.com. Just type in your model number and the part will be located under the "Top and Cabinet" heading as item number 11 (Part number 3949238).
Mar 21, 2010 | Kenmore 23822 Top Load Washer
I have a kenmore refidgerator with loose door handle
usually there door tightening screws at the top edge and bottom of most frig doors there will be plastic caps covering the screws..
Nov 14, 2009 | Washing Machines
My Whirlpool Gold side by side refrigerator when you open the refrigerator door you hear the sound of maybe a relay trying to open and shut. The display panel that shows the thermostat setting is off and...
sounds like your having an issue with your door switch its just not opening the machine still thins the door is closed
that clicking you hear could either be the switch itself arcing inside
not knowing your model number i cannot be sure
but that is ehre id start
www.appliancepartspros.com
type in your model
the door switch should be in the body/cabinet section
Oct 26, 2009 | Refrigerators
Light will not come on. not the bulb. everything
First lets start by unplugging the refrigerator and checking 4387911 Refrigerator Door Switch. Then let me know if the door switch is good or bad. You can find this switch part number by clicking the part number and model number search feature below. Enter the part number and press FIND IT. Let me know what you find with the door switch possible problem and if not the switch I will go to step 2, Thanks, Sea Breeze
PART NUMBER AND MODEL SEARCH FEATURE
Aug 05, 2009 | Whirlpool ED5FTGX Side by Side...
Whirlpool 21.0 cu. ft. Top Freezer Refrigerator with IceMagic Plus Ice Maker Logo
83 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
