Question about AT&T 5840 5.8GHz Speakerphone/Answering/Caller ID Answering Machine
Cordless phone my cordless phones will not work. out of the charger they say place in charger. in the charger it says that they are connecting and never do. this has been going on for several days.
  • phonefix Feb 16, 2008
    Replaced batteries - same result.
    Swapped batteries - now two dont work.
  • 47 Answers
You need to reset the security code between the base and the handset
Posted on May 11, 2008
I want to get 2 phones,1to connect to landline, and 1 by my bed.
this can be overcome by either running a piggy back connection at the input point of the land line and running the extension wire to the other phone
by buying a cordless phone set ( 2 phones ) and placing the base set at the point where the existing phone is and the other cordless phone in the room
the base phone set connects to the land line and the second phone is by wireless transmission to that base set
all you will need is a power supply for the second phone as it has a charger as a stand for the phone
Sep 23, 2015 | Cell Phones
Will not hold charge / shuts off
the batteries may need replacement. 2 aaa size ni-mh 560 mah 1.2 v are required. or the charger may be defective. If the charging light or the battery bars show up in display when placed in the cradle, the charger may not be defective.
Mar 16, 2015 | Uniden DECT 6.0 Cordless Phone ID
Phone has beep & no dial tone. Screen says its searching
I was unable to locate a manual for your phone online, but can offer some suggestions to solve your problem.
Most cordless phones beep in battery low, out of range, and other situations. Since it is also displaying the "Searching" message, it indicates that it lost its link with the base due to being brought too far from it or the battery power has fallen to low to permit use as far as it may have worked before.
The quick fix is to simply place the phone into the base / charger. This re-establishes a security link between the cordless handset and your telephone line. This is a safeguard that is used to prevent others with the same cordless phone from merely getting "near your base / charger" and gaining access to your dial tone to place calls on your phone line.
If the battery is low, it should left to remain on the base / charger long enough to fully charge the battery. If the battery fails to charge, there may be an issue with the base / charger; but it is much more likely to be a problem with a battery that has reached the end of its useful life (batteries seldom last more than a couple of years and may not last a single year depending on usage). Either condition will require replacement of the faulty device before using again.
If you need more help, you may want to try Thompson Electronics (if purchased prior to 2011) at 800-448-0329 or their website; as it appears GE contracts with them for support after the warranty period.
Mar 30, 2012 | GE 27990GE3 Cordless Phone
My telstra 8100 cordless phone keeps showing the word searchingnow i cant do anything with the phone.hope someone can help. Cheers
Place the telstra 8100 handset in the charger. Call any number while the handset is in the charger and it should dial out - you can hear the dial tone now. Take the handset out of the charger and you should be able to call normally.
cheers Matt
May 16, 2010 | Cell Phones
2nd request: Model 27956 GE Cordless Handset with Picture Caller ID & Slide Show. Won't work after power outage. White & gray screen only. Disconnected and reconnected as advised by service call....
This fixed mine:
To fix this issue:
1. Unplug the Unit
2. Unplug the Phone Cord
3. Disconnect the Battery from the Handset
4. Wait 10-15 minutes… and put back together in Reverse Order
5. Connect the Handset Battery
6. Plug-in the Phone Cord
7. Plug-in the Unit
Sep 02, 2009 | Uniden Cordless Phone
Phone wont connect to verizon. message on phe says place set in
Unplug main unit and the other unit which is not working then plug back on after few minutes. If its still the same then change battery on hand set. baattery life is only four years
Mar 26, 2009 | Vtech 5.8 Ghz Handset Cordless Phone...
Phone not charging even with new batteries
Reboot your phone system. I'm not kidding. Unplug base from power and phone line for 1/2 hour and unplug battery from phone.
Feb 19, 2009 | AT&T 650530003417 Cordless Phone
Problem with ATT cordless phone set (3 phones)
I wonder if any one who asked this question got an answer to this good question. I am having the same problem. I need some help.
Nov 26, 2008 | AT&T 2256 Cordless Phone
MA355 Cordless Phone Makes Noise when IN CHARGER?
yes this happens to me also. I haven't tried anything to fix it but it is darn annoying.
Apr 26, 2008 | Uniden Cordless Phone
Charger no longer charges
Clean the Contacts with an eraser, fine steel wool or light sand paper.
Feb 18, 2008 | Logitech MX1000 Laser Cordless...
AT&T 5840 5.8GHz Speakerphone/Answering/Caller ID Answering Machine Logo
141 people viewed this question
Top AT&T Lands Phones Experts
Paul C.
Are you an AT&T Lands Phone Expert? Answer questions, earn points and help others
