Question about InFocus LP350 Multimedia Projector
Light not turning on
My light bulb will not come on and it does not appear to be blown out
    Sergeant:
  • 202 Answers
Your light switch is bad try and bypass the switch
Posted on Jul 24, 2009
No Picture. On/Off light starts out red then immediately turns white, then the white light blinks 7 times about a second apart. Then no picture-no sound but the TV does appear to be turned on. Fuse S2 was...
Have you tried the manufactures web site to decode what the flashing lights may mean? Not knowing the manufacture it could be simply a burned out bulb.
Nov 12, 2014 | Televison & Video
Dashboard and tail light is out....yet the fuses inside and outside the car, are not blown. What could this be??????
Hi Leslie, To answer your questions, 1) a fuse can look undamaged and be open circuit (blown) 2) One bulb being blown should have no effect on the other, but if both are blown, the vehicle will have no tail lights! 3) The bulb holders should have no effect on each other, but if the earthing is bad, which is possible on a vehicle which has any rust, the problem could be related. Take a short length of electrical cable and while holding one end to the outer metal housing of the bulb holder with the rear lights switched on, connect the other end to a good metal earth on the body. If the lights or light works the problem is the earth connection. Regards and happy new year John
Jan 06, 2013 | 1991 Honda Accord
I have no tail lights when i turn on my head lights
check your tail light fuse, or blown bulbs. Just do a small test before you strip. Put someone in car turn ignition on and just apply brakes, if the brake lights come on means you have tail lights bulbs blown . If you have no lights at all go again for bulbs or fuse.
Aug 25, 2012 | 1995 Nissan Pathfinder
In the instrument panel there's this yellow light of a car with flashes coming from the back while i'm driving
You have a bulb in the rear of your car that is blown. Try turning the car off then back on without pressing the brakes. If the light does not come on, press your brake pedal down and then check to see if the light appears again. If it doesn't, your brake lights are okay. Next turn your park/headlights on. If the light appears in the panel, you have a blown rear bulb. The light will come on if any of the rear bulbs are blown so you will have to visually check it while the lights are on to see which one is defective. It's best checked at night or right before sunset so you can easily see which bulb needs to be replaced.
Jun 14, 2011 | 1998 Lexus ES 300
No brake lights (bulb works when lights are on), no rear turn indicator lights(front turn indicators are working and rear bulbs do not appear to be blown)
The first thing i would check is the stop safety switch located under the brake pedal or brake pedal arm. If this piese has failed there will be no current to the brake lights when you apply the brakes
Jun 13, 2011 | 2007 Ford Fusion I4 SEL Sedan
How to replace bulb in front bumper turn signal housing 1995 jag xj6
hello,
  • Identify the blown bulb. Note that if a headlight bulb has blown, the dip beam is on the outside and the high beam is on the inside. Turn off the ignition switch and light switches.
  • Open the hood and replace any blown headlight bulbs. Press the plastic spring clips and remove the bulb holder from the assembly. Pull the bulb out of the bulb holder and replace it with a new bulb. It only fits one way. Be sure not to touch the bulb's glass. Replace any parking lights at the same time, they are in the headlamp unit too.
  • Remove the front turn signal light unit in the bumper to change the turn signal bulb. Push gently on the inside edge and insert a blade between the bumper and the lens at the outside edge. Compress the spring and remove the lens. Fit a new lamp by inserting it into the plug. The side marker light is changed using a similar process.
  • Open the trunk to replace the rear fog light, stop light, tail light, reversing light and turn signal light. Remove the rear light cover and turn the bulb holder fastener 90 degrees counter clockwise. Remove the expired bulb, fit a new one and replace the parts, turning the bulb holder clockwise.
  • Thanks..
    May 21, 2011 | 1995 Jaguar XJ6
    2006 ram1500 my left headlight will not work on low, high beams and driving lights are fine
    If your vehicle is 4 years old, I would suggest replacing both left and right headlght bulbs. It appears that your low beam filiment in your left light bulb is blown. I am assuming the wiring to the light socket is OK. Your local auto parts store can help you with this and sell you the correct bulb type for your vehicle. The bulbs are accessable behind the light assembly. The socket the bulb sits in can be removed from the rear of the light housing by turning it counter clockwise and pulling out. Replace the bulb. Don't touch the new bulb glass with your hands, but use a clean towel as not to get any oil on the glass. Rinstall bulb into socket and place the socket back on the light housing and turn it until it locks. Hopfully your truck is friendly and you can reach behind the light assembly easy.
    Hope this helps.
    Jan 01, 2011 | 2002 Dodge Grand Caravan
    Brake lights not working, but middle brake light works.
    Try cleaning the contacts with a wire brush if they appear dirty and then apply a small amount of silicone to the bulb contacts also try replacing the bulb as sometimes they don't appear to be blown but are
    Jul 31, 2009 | 2003 Toyota Corolla
    Both front blinkers don't work, but rear ones work fine. Fuse is good for turn lamps.
    It is posible both bulbs are blown, I have overlooked this before, if not you will have to change the turn-signal switch (in the stering colume.
    May 03, 2009 | Ford F-150 Cars & Trucks
    138 people viewed this question
    Top InFocus Office Equipment & Supplies Experts
    jasbo
    jasbo
    Are you an InFocus Office Equipment and Supply Expert? Answer questions, earn points and help others
