Question about RCA Scenium D40W20 40" Rear Projection HDTV
No Picture when I turn it on
I press the on button, the light turns green, I hear a light whine and then the on button green light goes off. I changed the flyback transformer. Could it be the HV splitter not getting power to the bulbs? Or did all the bulbs go bad at the same time?
  • Terry_J Dec 06, 2007
    My RCA D40W20 Projection Television is only 3.5 years old and will no longer turn on. After pushing the ON button once, the green light blinks on and off three times then shuts off. You cannot get the green light to come back on again for at least a minute. After the 1-minute wait period, you push the ON button again and it goes through the same sequence. This problem started slowly at first and the TV would eventually come on after many tries (while it was on, there were no problems with picture, color, brightness or any controls, which makes me think there is nothing wrong with the bulb). My solution at one point (after taking almost a whole day to get it to come on) was to leave the TV on 24/7 and put it on a blank channel when I wasn't watching it so the bulb was not in use. This worked until one of my children accidently turned it off and now it won't go back on at all (it's been six weeks since it went off, and I have tried turning it on several times every day since). Is there a solution to this problem that doesn't cost more than the TV is worth? I have been on several sites where many owners of the RCA LCD and Projection TV's (in all sizes) are all complaining about a very similar problem. Does anyone know if RCA is doing anything about this? I have had RCA TV’s since the mid 50’s, and they always lasted between 15 and 20 years. What’s with their products now?
  • 1,030 Answers
Changed the flyback? why ...did u check the horizontal ouput transistor. usally they go hand and hand with flyback
Posted on Dec 10, 2007
My Mitsubishi 73 in SDLP works fine for about an hr then turns green and starts jumping. I can turn it off and back on and it's good for about 15 mins. If its off for a while it starts within a hr
Hello. When the picture changes color after warming up, chances are that the color wheel is defective. If you get close enough, you might be able to hear a whining sound. If you do hear a whining sound, you definitely have a bad color wheel. Some color wheels are still available from Mitsubishi. Good luck!
Jul 31, 2016 | Mitsubishi Televison & Video
Mitsubishi Medallion does this
hi there,
Check for bad solder on convergence module. May have bad stk's. Do not neglect looking for bad solder on dsignal and defl boards. Mitsubishi is very prone to bad solder.
May 26, 2008 | Mitsubishi WS-55411 55" Rear Projection...
I have an Electrolux EWD1477. I have been away for four months and I'm having problems with it. I set to do the quickwash30 program and press start, you hear the clicks, it might put some water in then...
My EWD1477 was doing this a year ago and I fixed it. Then it started doing it again a month ago and I seem to have cleared it again.
Firstly, remove the drain hose from where it is inserted into a laundry sink hole to make sure it is not blocked or sealed in with sludge.
Secondly, make sure the machine is empty of water and clothes and then turn the machine to off with the Program Selector Dial. Then turn off the power at the socket and remove the power plug and leave for five minutes.
Step 1: put the plug back in and turn the power back on.
Step 2: turn the selector switch to the right (Whites/Intensive). The green light of the Start/Pause button should be flashing and the green lights on for Prewash/wash, Rinses and Spinning. Don't press any other buttons or change any other settings.
Step 3: press the Start/Pause button and wait for the machine to empty any excess water. Press it again immediately after you hear water flowing into the machine OR two audible clicks. The machine is now in pause mode with the green light of the Start/Pause button flashing. Only the green light on the Prewash/Wash button should be on. Leave it in pause mode for 30 minutes and then press the Start/Pause button to recommence the cycle.
Step 4: If the Start/Pause button begins flashing, water stops flowing into the machine and the three green lights mentioned above are back on, turn the Program Selector Dial back to off, wait 10 seconds, and repeat the process above.
Step 5: If when you then turn the Program Selector Dial to Whites/Intensive and hear the two audible clicks, immediately press the Start/Pause button to set the machine in pause mode. Wait 30 minutes. Then press the Start/Pause button to recommence the cycle.
Hopefully the cycle will run without a problem.
Mar 26, 2011 | Electrolux Washing Machines
After researching online, my TV problem seems pretty common. TV - Mitsubishi 1080 series WS 55511. Green blinking light blinks for 3 seconds, then goes out and TV never turns on, but I hear a slight...
The green light is known as "The blinking green light of death". This refers to the green LED on the front panel of the TV that normally blinks when turned on after a power failure or when unplugged: the green light is supposed to flash for about 1 minute while both microprocessors boot up: If it won't stop blinking it means that they aren't communicating w/each other. Unfortunately, it's common in Mitsubishi & other RP TV's. Getting this fixed by a professional is around $6-700 with labor, parts, etc. It's really not worth it in my opinion. I would go out and buy an LCD or an LED TV.
Nov 28, 2010 | Televison & Video
My akai flat screen tv is not turning on. the red light at the bottom of the tv is on and when the tv comes on the red light turns green and in a few seconds the tv comes on, when i press the power button...
i have one of these akai 27 inch with dvd, i had a similar issue i found a power supply at auction and exchanged it and it works fine now, normally with this symptom your power supply is fualty. if the light goes green and you have no picture then you know other boards are fualty
Jun 04, 2010 | Akai LCT3285TA 32 in. LCD Television
Techveiw flat panel plasma no picture when turned on
recently when i press the on button the tv light will turn green but i will only get a picture once in a while
Jun 04, 2010 | TechView P4204TW Television
No sound/picture and red power light always on (Hitachi 43FDX15B)
When u turn the tv on,u hear alot of clicking?That mean the Ballast that help the projection bulb to work is dead.Change the Ballast,might as well change the bulb too.U don't know what is the condition of the projection bulb in.
May 29, 2010 | Hitachi 43FDX15B 43" Rear Projection...
Mitsubishi WS-55909 dm board repair
The DM is fine if the led isnt blinking. Your set is going into protective shutdown. Try pressing the menu and the device/input buttons on the set both in together for 5 seconds to see if the set will blink a series of blinks pause then blink another series of blinks. Such as 2 blinks pause then 2 blinks, Then let me know what the blinks were and I will assist you with whats wrong
May 28, 2009 | Mitsubishi WS-55809 55" Rear Projection...
No picture, no sound.
Hi i have a pilips 42" plasma tv (42PF5320/79) i can hear clicking the green light is on and the tv will go into stand by if i press the power button and the red light also comes on .I have turned it on and off and it works now nothing just the light on the front as if its working looking at the back through the slots two green lights come on then the tv clicks and they turn off,thanks
Aug 06, 2008 | Philips 42PF9630A 42 in. Plasma Television
RCA Scenium D40W20 40" Rear Projection HDTV Logo
75 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
