SOURCE: 9 cycle heavy duty 2 speed washer machine
Buba, check the lid switch for proper operation, on a lot of models if the lid switch is bad, no spin, no drain. You said you had the pump checked out. Im assuming that it was removed to check for a sock or other garment lodged in the pump. Other things you can check would be the hose from the pump to the tub, make sure it's clear and the drain hose where it exits the washer. Hope this solves the issue..
SOURCE: Proline W1000 washing machine keeps on triping main electrical switch
check for water leaks,unplug heating element,and try again.or the motor,then try again.
SOURCE: Avanti 12 bottle wine cooler...switch
CHANGE THE CAPACITORS ON THE POWER SUPPLY (TO SAME VALUES) AND REMOVE THE JUMPER (CATODE OF THE BRIDGE TO THE CAPACITOR DOUBLE VOLTAGE)
SOURCE: brivis central heating fan will not switch off runs continuous
brivis wombat 2P 20 ducted heater, gas fires up but fan not starting
Any suggestions...???
