Question about Panasonic Strada CN-NVD905U GPS Receiver
Unable to access most functions....
Cannot access Address, POI, Nearest POI, Coordinates, Phone Number, Install settings.... Why is this? I just had this system installed in my mecedes clk 500. Anyone know why I cant use these options?
Hi !! If you dont plug park brake and light switch, some options will be blank. Turn off power supply conect those plugs (im advice you to do not conect speed cable). Turn on them reset the unit.
P.S. The park brake cable can be conected with tre ground. This way you can watch dvd with the car in moviment...
Go to the panasonic web and download the last update for your unit !!
I hope it helps yous... sorry my english....
Posted on Nov 27, 2007
Entering coordinates
When you press on your Where to? graphic a menu will come up that will give you a number of choices including
Address, Go Home, Points Of Interest, and 3 others. There should be an arrow point down in the lower right corner of the screen. When you press that the screen will scroll down a page and you should then see the Coordinates Globe. Press this and the screen should change to the Enter Coordinates screen. This will allow you to enter two sets of coordinates for your destination.
May 29, 2010 | Garmin Nuvi 350 Car GPS Receiver
How do I use coordinates? I entered map coordinates and it took us to the wrong place.
Some Tomtoms can use latitude and longitude coordinates. They refer, of course, to points on the map.
To use coordinates on some tomtoms you tap the Browse Map option. A general Map of the route is displayed. The screen has three buttons at the bottom
  1. Options
  2. Find
  3. an icon for the point on the map.
  4. Done
Tap the Options button: The Map detail Preferences appears, offering the choice to put a check mark in POI, Favorites, images. At the bottom of screen you have 3 buttons : POI, Advanced, Done.
Tap Advanced: In thsi screen you can put a checl mar on Names, Markers, and Coordinates.
Put a Check mark on Coordinates and press Done, Then Done again until you exit all those options.
Now your tomtom is configured to display coordinates. Be aware that GPS technology was created for military purposes and its civilian uses cannot be expected to offer pin point accuracy. It took an act of the US president to allow its use for civilian localization.
When you plan a route you can use longitude and latitude. Here is the icon you should like for.
Dec 30, 2009 | Tomtom ONE XL GPS
I have a address saved to favourites and I would like the co ordinates for this address. Ger
Get Settings\System\GPS Simulator=>ON and depress OK & Back
Now get Favorites\=Address_you_need=\Show map\Set Lo =>
You'll see car symbol stands on this address, go Back
Now get -\ Coordinates=> you' see them!
2. Solution
Download POIEditor for PC and install
Copy .gpx files from unit to PC an open them
You'll find a list of favorite addresses and their coordinates.
Aug 27, 2009 | Garmin nuvi 200W GPS Receiver
Can;t use intent on mobile
Here is what you should do step by step:
I.Configure your Computer
1.Install Bluetooth Adapter
2. Bluetooth Configuration->Local Services-> Add Serial Services ->Bluetooth Serial Port->Properties
Check – Startup Automatically
Check – Secure Connection
COM Port: COMx( mine is COM6)
3.Control Panel -> Phone and Modem Options->Modems->Add-> Check Don’t detect my modem->Next->(Standard Modem Types)->Communication cable between two computers->Next-> on witch port do you want to install it ? -> Selected ports -> COMx ( in my case COM6)->Next->Finished
Now in phone and modem options->Modems you should have : Communications cable between two computers : Attached to : COMx ( COM6 my case)
Select Communications cable between two computers -> Properties->Modem-> Maximum Port Speed : 115200 -> ok ->ok.
4.Control Panel ->Network Connections ->Create a new connection-> Next->Set up an advanced Connection-> Next-> Accept incoming connections->Next-> Check : Communications cable between two computers ->Next-> Check: Do not allow virtual private connections->next->next->select: Internet Protocol(TCP/IP)->Properties:
Network access : Check Allow callers to access my local area network
TCP/IP address assignment : Specify TCP/IP addresses:
To: 192.168.0.y (y=52 in my case)
5.Network Connections
Bluetooth Network -> Enable
Internet Connection ( your internet connection ) -> properties->Advanced->Check:Allow other network users to connect trought this computer’s Internet Connection->OK
If all goes well : Bluetooth Network-> Properties-> Internet Protocol ( TCP/IP)->Properties Should have the following setting:
Checked Use the followind IP address:
IP address:
Subnet mask:
6.Start->Control Panel->Administrative Tools->Services->Routing and remote access->Properties->General: Startup type : Automatic - this service MUST be started
**7.Install AnalogX Proxy (for the latest version)
Proxy->Configure-> Proxy Binding: 192.168.0.x ( for me x=50 )->ok.
! If you use a proxy, remember to start it .
II. Configure Phone:
1.Install GnuBox - ( for the latest version)
2.Configure Access point
Tool->Settings->Connection->Accces Points-> New Access point->Use Default Settings
Connection name: Bt
Data Bearer: Packet data
Access point name : Bt
User name: none
Promt Password: NO
Password: ****
Authentication: Secure
Homepage: none
Option->Advanced settings
Network Type: IPv4
Phone IP address: Automatic
Name Servers: Automatic
**Proxy serv. Address: 192.168.0.x ( for me x=50)
**Proxy port number: 6588
3.Configure all the applications from your phone witch require internet acces to use Bt Access Point
4.Configure GnuBox
Options->Install Set to GPRS
Options->Install Create Records
Options->Install->Copy settings from GPRS
Options->Install->set RAS login script
Exit GnuBox
Open Gnubox
Options->2box Bluetooth->Serial Port
Select – your computer
Do you want to require encryption? Yes
Options-> Install->change default AP
** Configure NetFront
Enable Proxy : Yes
Proxy Host : 192.168.0.x ( in my case x=50)
Now you can browse the internet from your phone.
NOTE: First Configure the phone and your pc without the ** settings, and if you can’t browse the Internet form your phone then use the ** settings.
Hope this works fine.Thank you.
Nov 25, 2008 | Computers & Internet
Software update
This is a known problem with 7.4x versions....
You have done the right thing,
downgraded to V 7.221....
Apr 26, 2008 | Tomtom GO 920 GPS Receiver
POI menu with custom POI does not appear anywhere on the C330?
You need to use Garmin POI loader to input custom POI. After loading POI's they will show up in "My Favorite" under "Custom POI"
Jan 10, 2008 | Garmin StreetPilot C330 GPS Receiver
Gps coordinates
If you are asking to put latitude and longitude information into the C330, no, the unit is not designed to accept that type of information.
Nov 24, 2007 | Garmin StreetPilot C330 GPS Receiver
Cannot access Address, POI, and Nearest POI.
Nov 21, 2007 | Panasonic Strada CN-NVD905U GPS Receiver
Panasonic Strada CN-NVD905U GPS Receiver Logo
228 people viewed this question
Top Panasonic GPS Experts
Richard Foster
Richard Foster
Will Halftowaite
Are you a Panasonic GPS Expert? Answer questions, earn points and help others
