Question about Cell Phones
This link advises to disassemble the phone and put electrical tape on usb port; how does this problem happen?
  • Cell Phones Master
  • 19,396 Answers
Hi.
Please let us know if you are still experiencing troubles with your phone.
In that case, please add info on phone model and details on the problem.
Regards.
Posted on Dec 09, 2009
Can i directly hook up the neg and positive wire to my cell battery and charge it
popped off the battery cover and noyiced the + & - signs on the battery almost lined up perfectly with the contacts on the sides
so fugurring that since the charge from USB port, figured the 5V 0.5A power source would work for the same side connectors. cut up the seperate USB cable layng around and stripped down the red (+5V) and black (Gnd ) wires.
from there bunched them up and stuffed the red one into the left contact and taped it down with electrical tape and then did the same with the black wire in the right contact. make sure to use as much wire as you can without touching the 2 wires/contacts and taped them down seperately and nice and firm.
plugged in to the computer for about 25 min and it was completely drained and nearly 1/4 full power.wait for to get it fully charged and then just bring this cable and electrical tape with you and you can charge your cell with your lap top
Jan 14, 2012 | Cars & Trucks
Tip
Insert SIM Card Problem Fix
The "Insert SIM Card" problem can be irritating when it keeps on popping up even when a SIM card is actually been inserted into the phone's SIM card holder. It can sometimes be remedied by cleaning both the SIM card and the holder terminals with a cotton swab immersed in alcohol; most preferably 70% alcohol solution. Sometimes the holder is not tightly holding the SIM card causing the problem. This can be solved by padding up the back of the SIM card with a small sheet paper or any appropriate material enough for the holder to hold the SIM card tightly. Another way to fix the problem is by bending in the mid-section of the SIM holder cover.
Nokia 1110, 1110i, 1200, 1028, 1209 and all other member of the family of Nokia phones with USB ports similar to the ones mentioned earlier have the tendencies to experience the "Insert SIM Card" problem not due to a dirty terminals nor a loose holder but due to dirty, soiled, or oxidized USB port terminals. The fix is just as simple as cleaning the USB port terminals but make sure to remove the phone battery prior to the cleaning. Use a paper clip, a safety pin, or a needle with bended tip to scrape off the dirt between the port terminals and dip it in alcohol to wash it out.
The cleaning can be done without the necessity of disassembling the phone but if proper tools are available, disassemble the phone to clean the inside of the system connector, the one where the USB port, the charging socket, and the headset socket are located.
System Connector
People may wonder how a dirty USB port can lead to the "Insert SIM Card" issue and guess what; it is not even included in the Nokia Service Manual. The fix was discovered accidentally and proven many times that a dirty USB port is indeed the source of the problem.
on Apr 09, 2010 | Cell Phones
Well, one of my USB ports is broken. But, if one USB port is broken, the other one isn't working. What can I do to fix this problem? Is there a way that I can find the parts to fix this??? Also, it's...
Perhaps a couple of the contacts are shorted against one another. A Youtube search for disassembly of your laptop should show you how to disassemble it, but I suspect the USB ports are soldered to the motherboard.
If you can look at the broken port and cut out any loose, r shorted wire, you might get the other to work. You could also plug a self-powered USB hub into the other side, if it's working.. much cheaper than a new motherboard.
Jan 29, 2018 | Acer Aspire 5516-5063 Notebook
I have an acer 5740G laptop to which when i am connecting the MV 920 cannon cam corder through the camera's port in to the laptop's USB port, the laptop does not recognise this as an external removable...
This type of camera usually downloads better with a Firewire (DV) connection. Some mini-DV cameras only use the USB connection for stills (if they have one) and can only download video by Firewire. This is because you have to play the tape into the computer, not just copy a file.
Most PCs have a USB port, but no Firewire port. Macs often have a Firewire port but may not have USB. With desktop Windows PCs, you can fit an add-on Firewire interface card. This comes with a driver for the card. If your laptop doesn't have a Firewire socket, then you are probably stuck.
Nov 07, 2010 | Canon MV920 Mini DV Digital Camcorder
My usb port my mouse is plugged into wont hold, it's loose can this be replaced?
Hi:
This is not an easily replaceable part, and often these usb ports are directly soldered onto the motherboard. A good solution might be to buy a USB PCMCIA card that plugs into your PCMCIA card slot. This will give you extra USB ports, and won't require surgery on your laptop!
Apr 13, 2010 | HP Pavilion dv6000z Notebook
My lg vu will not charge
There are 2 possible problems you are having. You charger is going bad as evidenced by th cable going bad. Take it to a carriers store and try a different charger.
The other issue may be the charging port is going bad. Having to tape the charger may be an indication of that.
Try a different charger first but if that is not the problem check out the following link for ways to fix the charge port on your LG VU
LG VU Charge Port Repair
Jul 13, 2009 | LG Vu CU920 Cellular Phone
Can't link up to computer with usb cable. I want to upload...please advise.
please go to the camera setup option and change the output mode to USB....... connect the camera again to the computer and transfer your file ....
May 29, 2009 | JVC 32x Optical Zoom MiniDV Camcorder
USb cannot recognized
Your phone would normally come with software load this software onto your pc, if you do this then your pc will recongnize
May 26, 2009 | Sony Ericsson W850i Cellular Phone
How do i disassemble a t- mobile mda cell phone?
Hay Saeedm
check out this link
http://www.cellphone-repair-shop.com/HTCMiniUSB.htm
I have the same issue. i just dont know how to get the parts together
DDD
Feb 27, 2008 | T-Mobile MDA
ZENITH VCR TAPE KEEPS EJECTING
Got pets or young ones? This problem just smacks of having something lodged inside. Could also have come from a label coming off inside, too...accordianman
Jan 19, 2008 | Zenith VCS442 VHS VCR
Cell Phones Logo
21 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
