Lexmark X4270 All-In-One InkJet Printer
Problem for Lexmark X4270 All-In-One InkJet Printer
Error#1203
By dunny78 on Nov 21, 2007
my lexmark x4270 has a error#1203 and i dont have manual
Same Problem
Feb 09, 2009
-   error 1230 how to fix it
'-   supercor
Feb 01, 2009
-   I had the same issue when I was replacing my cartrideges with refilled ones. If you asnwer old to the new or old question it fixes the problem.-   Guest
Jul 23, 2008
-   No users guide. Took out the cartridges and reinserted them. Pressed the select buttons as requested to identify the cartridges being installed.When selecting the saved option, the printer went to error#1203. I need to print a boarding pass for the airline 7/23.-   gbyrd3
Jul 21, 2008
-   I request the collaboration for the solution of the error # 1203 which has left me not perform any function thanks -   ramiresbohor
Jun 23, 2008
-   Was trying to make color copies and got the 1203 error. I tried cleaning and still have the same error. Any other suggestions?-   petfor
Best Solution
posted on Nov 21, 2007
Helpful)
Cstufftek
Rank: Wiz
Rating: 84%, 129 votes
Check to see if any ink is smeared inside the holder where the contact panel is located. Normally gold contacts.
Clean off the contacts with a paper towel or q-tip.
Then try reprinting the alignment page. Then print the test page a few times.
Hope this helps
Was this helpful?
Yes
No
Solution #2
posted on Sep 03, 2008
Helpful)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
I had the same problem, and I took the advice to clean my printer heads...All i done was take out both, color and black ink cartridges, wiped them with a dry towel very softly, and reinserted them. It came up with 2 messages to confirm the colors item number, i pressed select like 6 times, then it printed an alignment page...I was good to go from there! Good luck to others!
Popular Solutions for Lexmark X4270 All-In-One
Questions and Unsolved Problems for Lexmark X4270 All-In-One
Do you recommend Lexmark X4270 All-In-One InkJet Printer?
Answer
Answer
I have a lexmark X4270 printer/fax machine. I replaced the black ink cartridge but the machine says... (More)
Answer
it says alignment page printing but to paper does not move
11 Other Users Have The Same Problem - Continued
Comment by Guest, posted on Jun 13, 2008
Was sending thru' a fax and before it finished, the error # 1203 appeared and informed to consult my user's guide which I don't have. Tried to do an alignment and test page and won't allow this step.
Comment by Guest, posted on May 08, 2008
i cannot fax anything because of te error #1203..
Comment by Guest, posted on Apr 08, 2008
i refilled the color and black ink cartridges and keep coming up with an error code of #1203 i don't have the users guide what do i do
Comment by bugface, posted on Feb 10, 2008
i just changed my in cartridges and now i am getting the error message 1203
Comment by kaynaz, posted on Dec 30, 2007
tried to clean as mentioned, still shows erroe 1203.
Comment by Guest, posted on Dec 10, 2007
error 1203 consult user guide
removed ink, clean & replaced
Describe your Printers problem:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Printer Experts
Top Printer Repairmen
in , CA
(800) 836-9287
Celebrating 14 Years Of Outstanding Printer Repair...
Laser Repair 911
(918) 583-5483
Elite printer Services, Inc. is a full service HP...
Elite Printer Services
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
