Question about Eidos Interactive Conflict: Global Storm
"You have been disconnected from online services"
Happens when i try to connect to multiplayer
    New Friend:
First disable your internet connection.Then open`conflict global storm.Then go in gamespy id login.Dont login ur id.Then minimize your game and enable your internet connection.Then login your id.
Posted on Nov 18, 2012
Contact with your iSP
Posted on Jul 24, 2009
How do you get the internet on this my says no compatible access point in range check your connection setting under internet opion and try again error code 051099
Unable to use your wireless signal
Likely cause: It appears that the settings entered into the Nintendo DS are not compatible, or the router's broadcast settings should be changed.
How to fix: Try creating a new connection with your system. Nintendo DSi owners trying to play multiplayer games will want to be sure to read the "Trying to play online multiplayer with Nintendo DSi."
  1. Create a new connection: This error can occur if a setting (like your network's name) has changed since you last connected. If it's been awhile since you connected, or if this is your first time connecting, creating a new connection file will often resolve this error code. Click the button below for your system and we'll walk you through the connection step-by-step.
Even if you are able to connect online and use other online features of the Nintendo DSi, if you are attempting to play multiplayer games but are receiving error code 51099 when you try and connect, then your router is likely using a security type - WPA - that is not compatible with Nintendo DS Game Cards.
Try this:
If you are sure you are using WPA, click here for more information including alternative connection methods. If you're not sure if you're using WPA, you can find out by going into the connection settings on your Nintendo DSi and doing a search for an access point. Follow these steps:
  1. Turn on your Nintendo DSi and access the System Settings by clicking on the wrench icon
mr_fix3er_0.png 2- Scroll over to the third page, and select "Internet."
mr_fix3er_1.png 3-Now choose "Connection Settings."
mr_fix3er_2.png4-Click on "None" for "Connection 1."
mr_fix3er_3.png 5-Click on "Search for an Access Point."
mr_fix3er_4.png 6-The Nintendo DSi will search for any wireless networks within range. Once it is finished searching, it will display the names of all the wireless networks it finds. Look for your wireless network.
7-What to do next will depend on the "lock" icon you see next to your network on the Nintendo DSi.
mr_fix3er_5.png No security - This connection type is compatible with Nintendo DS Game Card online multiplayer.
mr_fix3er_6.pngWEP - This connection type is compatible with Nintendo DS Game Card online multiplayer.
mr_fix3er_7.pngWPA - This connection type is not compatible with Nintendo DS Game Card online multiplayer. Security will need to be changed to WEP or turned off in order to play online. Click here for more info.
  • Other suggestions :
  • Make sure your router is set to broadcast in "b" or "mixed" mode. If your wireless router is transmitting in "N" only mode, you will need to switch it to "b/g" or "mixed" mode. For help accessing your router's settings, click here and select your router brand and model (if available). Most routers will have this setting in the "broadcast settings" menu.
    • Check for wireless interference, which can affect the signal strength to the Nintendo DS. To help minimize wireless interference, try the following:
      • Make sure other wireless devices such as cordless phones or wireless speakers are turned off, and that the Nintendo DS is an open area without objects or electronics blocking the signal.
      • Change your router's channel setting to 1 or 11. By default, most routers broadcast on channel 6, which overlaps with other channels and may be weaker. For help doing this, click here and select your router brand and model (if available). The information you need is found in the "Broadcast Channel:" area.
  • Still stuck? We can help! We have found that simply erasing the old connection file and creating a new connection to your router may help. Click the button below for a step-by-step guide. If at the end you still need help, you'll find contact information to reach our specially-trained representatives. Click the button below for your system and we'll walk you through the connection step-by-step.
    Apr 14, 2011 | Nintendo DSi Matte Blue Console
    I tried to contact the internet and it keep on saying your error code 051099 and i wanted internet
    Hi tabia tabz, Nintendo has an excellent walk-through on fixing just that issue. Instead of just re-ryping their information I will post it exactly as they had it because they offer very nice images of exactly what you need to do each step which should help you alot.
    Here is what Nintendo states:
    Error Code: 051099 Was this information helpful?Unable to use your wireless signal
    2. Trying to play online multiplayer with Nintendo DSi
      Even if you are able to connect online and use other online features of the Nintendo DSi, if you are attempting to play multiplayer games but are receiving error code 51099 when you try and connect, then your router is likely using a security type - WPA - that is not compatible with Nintendo DS Game Cards.Try this:
      1. Turn on your Nintendo DSi and access the System Settings by clicking on the wrench icon.
      2. Scroll over to the third page, and select "Internet."
      3. Now choose "Connection Settings."
      4. Click on "None" for "Connection 1."
      5. Click on "Search for an Access Point."
      6. The Nintendo DSi will search for any wireless networks within range. Once it is finished searching, it will display the names of all the wireless networks it finds.Look for your wireless network.
      7. What to do next will depend on the "lock" icon you see next to your network on the Nintendo DSi.
          unlocked.png No security - This connection type is compatible with Nintendo DS Game Card online multiplayer.
          lock_compatible.png WEP - This connection type is compatible with Nintendo DS Game Card online multiplayer.
          lock_wpa.png WPA - This connection type is not compatible with Nintendo DS Game Card online multiplayer. Security will need to be changed to WEP or turned off in order to play online. Click here for more info.
    3. Other suggestions:
    Feb 23, 2011 | Nintendo Dsi Pink Console
    I got 007 quantum of solace a few weeks ago and completed it on game mode so thought would have a go on multiplayer, although when i tryed to play it just leaves me hanging in match game lobby asif nobody...
    As this game is old now, Infinity Ward may have turned off the servers as there is not enough support for the multiplayer aspect. This happens regularly with game that are a couple of years old and not many people play online.
    Dec 16, 2010 | Dmm Bond 007: Quantum of Solace PS3 for...
    I have the game untold legends dark kingdom. i bot it a few days ago and whenever i go online for the game it says checking for update. after about a minute or so it says cannot connect to update server....
    it's not really a solution. but i have bad karma, i got my friend to come over to see the new game and he liked it and when i tried to see if the online worked it's been working eversince. my friend has good karma
    Sep 13, 2009 | Sony Playstation 3 (PS3) Console
    "cannot connect to gamesession"
    I don't think the game allows online play with 2 same cd keys...
    I'm not allowed to advise you to get another cd key from the net, because that is illegal.
    I guess you will need another copy of the game to play multiplayer.
    Apr 13, 2009 | Black Isle Studios Icewind Dale: Heart of...
    Call of Duty 4 keeps freezing
    It only freezes online during multiplayer a couple minutes into gameplay.
    Jun 21, 2008 | Microsoft Xbox 360 Console
    Do u have to pay to go online on the xbox 360
    Hello there.
    On the Xbox 360, you'll have two choices of service level: Xbox Live Silver and Xbox Live Gold. Xbox Live Silver will offer limited Xbox Live functionality at no cost, while the Gold package will be a fully functional pay service.
    The Xbox Live Silver service means you can connect your Xbox 360 console to a broadband Internet connection and get functionality right out of the box without having to pay any amount of money.
    With Xbox Live Silver you can:
    • Create an online Gamer Profile
    • Access the Xbox Live Marketplace
    • Engage in voice and text messaging
    • Talk to a single friend at a time using voice chat
    • Receive video messages from Gold level members
    • Access massively multiplayer online games (additional fees may apply)
    The Xbox Live Gold is similar to the current paid Xbox Live service. The Xbox Live Gold service delivers the complete online connection package. With Xbox Live Gold you have all the features of Silver level, and additionally:
    • Play multiplayer games online
    • Video chat
    • Multiplayer online tournaments
    • Participate in Xbox Live online programming, such as Game with Fame, Play and Win, and Prime Time activities.
    Hope this clarifies things for you.
    Apr 13, 2008 | Microsoft Xbox 360 Console
    Multiplayer connection
    Try making a connection so your friends can join you because i had this problem with Diablo 2 lol me and my bro were playing and he tried to connect to my Cpu but couldn't so i connect to his CPU just fine
    Mar 24, 2008 | Sony Playstation 3 (PS3) Console
    Multi-players on games onslim PS2
    On some games, Call of duty and medal of honour Rising sun, have a option for multiplayer. However, there are two types of multiplayer.
    First type is the one that you are thinking of which is to be able to play face to face with two controllers.
    Second type is online multiplayer which requires and internet connection.
    in essance Call of duty 1 & 2 are single player games.
    Jan 12, 2008 | Sony PlayStation 2 Slimline Console
    Eidos Interactive Conflict: Global Storm Logo
    548 people viewed this question
    Top Eidos Interactive Video Game Consoles & Games Experts
    Michael Vincent Cruz
    seanwalters1
    Level 1 Expert
    Are you an Eidos Interactive Video Game Console and Game Expert? Answer questions, earn points and help others
