Question about LaCie Rugged All-Terrain (301017) Hard Drive
I have a brand new Mac. I plugged in my LaCie rugged terrain external hard drive and nothing happens. Nothing! I can feel the device vibrating a bit, but the computer does not react in any way. The icon doesn't show up. What should I do?
    Master:
  • 404 Answers
Go to applications, utility folder, disk utility
then format the drive in any other way besides
dos.
Posted on Jul 24, 2009
My lacie 2 TB hard drive stop powering on
If you have a plug in power supply check to make sure it tests with the correct voltage, if okay! the problem is in the the internal circuitry of the hard drive and not built for service in mind.
Mar 29, 2012 | LaCie Rugged All-Terrain (301017) Hard...
Can a lacie rugged external hard drive be connect to a macbook -not macbook pro?
Yes - If the unit is USB it will work with any computer that has a USB port - if hooked up to any Mac though it normally will be formatted for use only with other Mac's. You can usually specify what type of filesystem you want to use when you have it hooked up.
Mar 16, 2011 | LaCie Rugged All-Terrain (301017) Hard...
Computer can 't recognize lacie hard drive
Does it show up in the device manager under storage or usb devices? When you plug it in do you feel the drive spin up?
How to get to device manager:
http://www.computerhope.com/issues/ch000833.htm
Mar 03, 2011 | LaCie Rugged All-Terrain (301017) Hard...
My Lacie hard drive doesn't show up as a drive on my mac. How do I connect it?
Hello Chris,
if your drive has a firewire connection, we will use it.
Once the drive is connected and your computer is on, you should feel the drive is starting to spin. Some vibrations are perceptible to the touch.
Usually, the drive icon would come up on the desktop or you will be prompted to initialize the new drive. If none of that happens, we will go manually into disk utility. Is the drive listed to the right? (go by capacity to try to figure out which one it is. If you have many drives of the same capacity and they are external, unplug them while troubleshooting your LaCie drive)
If the drive is not listed, try a different port on your computer, and if still nothing happens, try a different port on your drive if available.
If you have the USB only version, try plugging both USB at the same time. One provides power and data transfer, the other offers additional power.
If there is nothing showing in disk utility still, you will need to consider getting a replacement.
If you need any data that you manage to put on the drive at some point and your drive is out of warranty, you can take out the internal hard drive (which is a laptop sized drive) and connect it to a computer to see if you can access it that way. If it does not work, you will have to contact a data recovery company.
Regards,
Jan 15, 2011 | LaCie Rugged All-Terrain (301017) Hard...
My LaCie Rugged Hard Disk wont show up on my computer!!! need help asap or im getting firered!!
External hard disks can fail for a number of reasons, but check the device manager and disk management first to see if it is recognized (assuming you are using Windows).
Here are some more ideas: http://www.devicedriverfinder.com/blog/device-errors/external-hard-drive-troubleshooting
Sep 07, 2010 | LaCie Rugged All-Terrain (301017) Hard...
My lacie rugged 500gb triple interface normally worked but now doesn't load anymore. It makes a strange soft sound for 2 seconds and then nothing. help!!!!
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Hello,
Open the external hard drive cover, remove the hard disk inside, and fix it back. Try again and let's see what happens.
If it still does not work, insert the external drive into the computer, feel the hard drive if it spins/vibrate from inside or if it makes a cracking noise.
If it spins/vibrate, it means the hard disk is still working. In that case, you have to get another external drive case/cover.
But if it makes cracking noise, then it means the hard drive is damaged and you need to get another one.
I wish you all the best.
Jan 06, 2010 | LaCie Rugged All-Terrain (301175) 160 GB...
Unable to format
Try running a chkdsk on the device (from Instruments -> Check for Errors).
If no errors are founds, it's unlikely that a reformat might help (but you might try. If the device holds no data, you risk nothing).
It could be that the device isn't always getting enough power to go by: try plugging it into another computer, or use an externally powered firewire hub such as the Belkin F5U624eaAP.
Oct 26, 2009 | LaCie Rugged All-Terrain (301175) 160 GB...
LaCie Rugged All-Terrain (301017) Hard Drive Logo
1,303 people viewed this question
Top LaCie Computers & Internet Experts
Raj Patel
Tony
Are you a LaCie Computer and Internet Expert? Answer questions, earn points and help others
