First , do the headlamps work ? There is a fuse for the headlamp switch F2.17 - 15 amp located in the central junction box ( inside the vehicle fuse box ) also F2.7 a 30amp . . When you turn on the headlamps or just park lamps the dash lights an the running light's should come on . I see in the wiring diagram that there is a microprocessor involved in the operation of the lights . Also i see there is a relay PARK LAMP relay located in the vehicle security module .
SOURCE: changing instrument panel light bulbs
You have to remove the entire cluster assembly to get to the bulbs, there is no other way, no room for this man's hand at the back.
SOURCE: instrument panel lights and running
Under the Hood there is a Fuse Relay Box on the Drivers side close to the Top. In that box is a Relay Labeled "Illumination" Change this Relay.
SOURCE: instrument panel not working
Look in the Fuse Relay box under the Hood and Replace the Guage Relay. Should get it Fixed.
SOURCE: where can I find the fuse box that is supposed to be under the instrument panel on the driver side
You have to lay on your back under the steering wheel (pain!!) and get a flashlight ..... its under there. Just a STUPID location. (close to the plastic cover aroung the steering wheel shaft)
SOURCE: Where is the fuse for the instrument panel back
The tail lights and the dash lights are on the same fuse, so , if you don't have dash lights then there is a good chance that your tail lights are out too. There is a fuse in the fuse box on the drivers side end of dashboard, which can only be accessed if the door is open, replace the one marked "tail lamps " and see if this doesn't fix it.
