Is it sparking between boots or is it from the boot to the engine? You need to use dielectric grease on the boot on the coil to stop leakage of voltage between coil towers, I can't find the 2006 laser so chose a model similar to that model. With the engine off and you pull the spark plug wires put a little bit of the special grease on your finger and put it on the inside of the boot of the spark plug wire at the coil and at the spark plug. Be sure to not get any on the spark plug metal tip or on the metal on the coil pack. When removing the spark plug wire from the coil and plug be sure to twist it with the engine being cold so that you don’t ruin the spark plug wires. This should stop the leakage, if not then you have a defective coil/ coil pack and need to see if there is a carbon track or a crack in the coil assembly itself, let me know if this helps and get back to me if you need more assistance.
http://shop.advanceautoparts.com/webapp/wcs/stores/servlet/partlist_Ignition-Coil_190_R%7CGRPTUNEAMS__coil___
