SOURCE: Leaking dishwasher
when you state "there is water leaking out of the drain hose", then that leak must be fixed either by a new hose or to repair the hose. as far as the timer issue, i need more info.
SOURCE: Oil leaks from the oil filter adapter
If it is not the suggested gasket that is leaking then it is the oil pressure switch located exactly above the oil filter adapter. The black plastic housing could have developed a crack and oil will ooze downward and drip off the bottom of the adapter. I had this problem and changing the oil pressure switch took care of it.
SOURCE: Tetra filter Leaking after cleaning
Tetra tech support can help you or email you a new owners manual. Call their toll free number 800-526-0650
SOURCE: how remove and clean filters from Brookstone pure ...
how to remove and clean filters for the Pureion UV air purifier?
SOURCE: Dishwasher Kitchen-Aid (Hobart)
It is a very old dishwasher and you may not find many of the parts anymore.
There is a site where you can get the diagram from but the quality may not be very good. It mentions a 5/16" screw but not 3/8". I am assuming it is the same.
Check this out. You will have to click on the link under the diagram to print it out for better clarity.
Hope this helps. Please post a comment to confirm.
