Question about Polaroid i631 Digital Camera
CAMERA DROPPED AND LENSE IS STUCK OUT AND CAMERA
I631POLAROID CAMERA WAS DROPPED AND LENSE IS STUCK OUT AND CAMERA WON'T TURN ON
    President:
  • 672 Answers
Your len's mechanism is damaged or jammed. It would be too expensive to repair!!Hopefully this helps
Posted on Jul 24, 2009
My friend had dropped my camera while handing it to me. The lense is stuck out and it wiggles. When I turn it on the camera comes on for half a second and shuts off.
Hi. The lens has been knocked off track and probably damaged since it was dropped.
If the lens is stuck at an angle it could possibly be repaired by snapping it back into place. Otherwise you will for surely need to have a new lens installed.
You can purchase a Lens for around $15 - $29 on Ebay. Sometimes they
offer free installation.
Nov 06, 2011 | Kodak EasyShare C180 Digital Camera
The camera lense is stuck open and not will close
Hi! Better check it with qualified technecian. It might damage everything if you force it. The lense broke inside. It needs to be replaced or adjust the screw to lossen so that lens will go back to its original position.
Please feel free to comment.
jonags3
Jul 19, 2010 | Sony Cyber-shot DSC-W30 Digital Camera
Stuck lense on olympus FE-350
If the lens is stuck out then you will find it is usually one of a few reasons.
1. Check the batteries
(obvious I know).
2. The
camera has been dropped or knocked.
3. The camera has grit or dirt in the lens mechanism.
Providing the batteries are ok then 2 and 3 usually mean a professional repair. The lenses tend not to be something that the average
home user can remove and take apart. The cost of repair also might be more than the camera value so you will need to find a good repair shop near you and get a quote.
May 31, 2010 | Olympus FE-360 Digital Camera
Lense stuck out camera shuts downwith lense out
1. Check the batteries. (obvious I know).
2. The camera has been dropped or knocked.
Providing the batteries are ok then 2 and 3 usually mean a professional repair. The lenses tend not to be something that the average home user can remove and take apart. The cost of repair also might be more than the camera value so you will need to find a good repair shop near you and get a quote.
Apr 21, 2010 | Kodak EASYSHARE M1063 Digital Camera
Lens are stuck out. screen says "lens error"
There could be two things causing this problem.
1- some dirt somehow got on the outside of side of the lense. So the lense could not fully retract or open out. As a result you can not take any picture. If the lense comes out even a little bit, try to pull it out NOT too hard a few times. If it does not retract, turn the camera off and push the lense in (up and down) NOT too hard for a few times. If the camera opened up 100% or retracted 100%, your camera should be back to normal. Make sure to clean the outside of the lense when fully open and keep it clean always. If this did not help, read 2.
2- If you dropped the camera, some mechanical part of the lense is broken or dislocated or the cable may have come loose. In this case you need to take out the lense from the camera and inspect it for broken pieces or loose cable. clean the outside of the lense and push the lense in and out a few times. Put the lense back on the camera and your camera would be back to normal.
Good luck!!!!!!
Jun 11, 2009 | Olympus FE-270 Digital Camera
Kodak camera dropped lens cockeyed stuck open
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...
Here's some things that you can do to try to correct it. They only seem to work for less than 50% of the lens errors, but if the camera is out of warranty, they're worth a try:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Apr 08, 2009 | Kodak EasyShare V1003 Digital Camera
Lense stuck out and can't take pictures
In all probabilities, the lens barrel must have tilted, preventing the lens from retracting into the barrel. It could also be possible that some dust particles got stuck in between the segments of the lens barrel. Check for these. Try to straighten the barrel without using much force, and try to remove any dust particle that got stuck between the segments.
Jan 14, 2009 | Panasonic Lumix DMC-FX01 Digital Camera
Fuji finepix a600
If the camera was on when it was dropped you probably jamed the lense coil. The lense coil is what helps the camera smoothly pull in the lense and back out. Now, just to specify, what exactly are you having a problem with? Will the actual lense not go back into the camera when you turn it off; or can you not get your camera off zoom?
Let me know~
Olivia
Oct 30, 2008 | Fuji FinePix A600 Digital Camera
Lens won't in on camera and makes clicking sound.
When you dropped your camera, some dirt got on the outside of the lense or some mechanical part of the lense broke or dislocated. If some of the mechnical part of the lense is damaged, you need to open up the lense from the camera and inspect the parts. Look for loose parts, then clean it and put it back.
I had the same problem with my sony Cyber-shop, but it was not dropped. somehow one or more small piece of dirt got on the outside of the lense. Here is what I did and the problem was fixed for good.
While turning the camera off, I pressed on the lense (up and down motion) softly. After a few times, the lense retracted 95% of the normal retracted position. I then, pressed the lense a little harder in untill it was fully retracted. It has been working okay since then.
You should always keep the outside of the lense clean and do not drop it.
Good luck
Oct 11, 2008 | Sony Cyber-Shot DSC-P32 Digital Camera
Polaroid i639
Ok, i just had this problem 5 minutes ago because i dropped my camera. I know, very stupid of me! but i was able to fix it myself, and hopefully you can too.
the problem is your lense. The lense being stuck causes the camera to automatically power off. if you can tell where the lense is stuck (you can usually see because it is jammed and lower than the rest, it slants in that direction) you may be able to pull it back out without damaging the camera. i just did this and i was so relieved!
Jan 22, 2008 | Polaroid i639M Digital Camera
Polaroid i631 Digital Camera Logo
226 people viewed this question
Top Polaroid Cameras Experts
Greg Cann
Greg Cann
Steven Wander
Steven Wander
Are you a Polaroid Camera Expert? Answer questions, earn points and help others
