Question about Philips Magnavox 50ML8105D 50" HDTV DLP TV
Ware is the bulb located in the 50inch magnavox
Took tv apart can not find the bulb dose any one know ware it is located in model number 50ml8105d/17 please help
    Scholar:
  • 167 Answers
  • hello here is what you need to know .on the location of your lamp & the right way to replace it. first thing is to, Turn off and unplug the unit before you replace the lamp.
  • Take care that no screws or other metal objects fall into the display interior. Such items could cause fire or electrical shock.
  • Do not remove the lamp except to replace it. Careless handling can cause injury or fire.
  • Do not replace the lamp immediately after the display is turned off. The high temperature of the lamp could cause serious burns. Allow the lamp to cool down at least two hours after turning off the display. display. ware is the bulb located in the 50inch magnavox - 051021165929_314.gifthank you for useing fixya.com .
Posted on Jul 24, 2009
  • MICHAEL WALLACE
    MICHAEL WALLACE Jul 24, 2009
My magnavox dlp tv model 50ML8105D\17 will not turn on
First check the lamp, if not then maybe one of the fans is running poorly. Make sure it is plugged in.
Nov 13, 2011 | Televison & Video
My 50" magnavox 50ml8105d/17 making a knocking
It sounds like you have a bad color wheel. If you are handy with electronics, it is a pretty simple fix. If not, I would suggest you take your set to a qualified service center.
Apr 01, 2011 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
I purchased a Magnavox / Phillips 50 inch tv a while back and am now told it needs a new bulb which I can not afford due too the fact of getting hurt and going on S.S.Disability and no extra income what so...
I don't know of anyone who can donate a lamp, but I have done research and you can actually purchase a lamp off of ebay for $85.99 and then have the technician install it. Here is a link to the ebay site where the lamp is located.
http://cgi.ebay.com/PHILIPS-313912877921-LAMP-BULB-50ML6200D-37-TV-/390236743138
Sep 18, 2010 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
I have a Magnavox 50ML8105D/17 the picture is getting darker
You need a new bulb replacement. The owner manual will even instruct you how to change the bulb.
Oct 24, 2009 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
Replaced the bulb on a 50ML8105D/17, the bulb starts to light but turns off at 5 seconds and the red led light on the front comes on.
Hi,try to reset lamp timer by unplugging tv wait 5 min and plug it back again.Check for clicking sounds it could be the ballast which is the board that powers the lamp that it could be bad.God bless you!
Oct 06, 2009 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
No picture
Pull the front cover off at the bottom. You will see a panel which has to be removed using a screw driver. Inside you will see the lamp assembly. It is a removable box. The lamp can be changed out by just changing out the connections on the new lamp. Before you pull it though try reducing your picture size to 4:3 it helped us to get a little more life out of our lamp.
Apr 07, 2009 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
Shutdown
Try cleaning the air filter and see if that solves the problem.
May 26, 2008 | Televison & Video
TV Magnavox 50ML8105D/17 Problem
I have the same problem my DLP TV would shut off after 30 minutes or less all red LED's. Solution: The fan on the lamp assembly was not turning at the proper RPM (bearing going bad) so it was going into overtemp mode. The original part number was a SUNON KDE1209ptv3 12v 1.3W I had a hard time finding one to match that spec. DIGI-KeyCorp (www.digikey.com) was able to cross reference it to a 3 lead P11034-ND part number (NMB-MAT model fba09a12L).
I Installed the fan and problem went away.
Procedure:
Remove the lamp from the lamp assembly
Remove the back panel.
From the back, slide the main circuit board to the left (loose one screw)
Remove the power interlock on the lamp assembly (2 screws)
Disconnect Lamp assembly cooling fan lead.
Remove the 4 silver slotted screws on the lamp assembly, 2 in the front and 2 in the back.
Carefully remove the lamp assembly from the rear. WATCH the Mirror.
Remove fan, cut leads and solder or **** splice on to the new fan.
Repeat steps for installation
Feb 21, 2008 | Televison & Video
Philips Magnavox 50ML8105D 50" HDTV DLP TV Logo
202 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
