Mitsubishi 65711 TV will not power on
When I turn on the TV green light fast blinks for sometime and then goes off, screen won't come in. Checked the code, it is 12. Have already changed ICs in DM module. Set looks completely clean from inside - no leaks or bad ICs. What can be the problem? Please help!
  • 1 more comment
  • kkbansal Jul 24, 2009
    I did changed capacitors on DM board although they were not bulging. This didn't fixed the issue. I have not looked at the fuses - how do I locate them?
  • 3,866 Answers
Did you check the power supply and does the supply have bulging capcitors? if so change those. check fuses as well those are located on the main board as well.
Thanks
Posted on Jul 24, 2009
  • Grand Canyon Tech
    Grand Canyon Tech Jul 24, 2009
    The fuses are square there not like a common fuse there should be 3 of them and there in a row with each other.
65" mitsubishi rear projection tv won't turn
IF model number posted is correct and green power light comes on for a few seconds and then goes off:
On front of set press and hold both the Menu and Input (device) buttons at the same time for at least five seconds and release both buttons.
Power light will then blink a two digit error code like 2 blinks, 2 blinks, a pause and repeat it several times.
Let me know what error code is found and I will tell you what it means.
SD TECH
Oct 09, 2011 | Mitsubishi WS-65611 65" Rear Projection...
Tip
I have a Mitsubishi WS 65711 When I power on the TV the green light (power...
Most of the Mitsubishi rear projection sets made from about 2000 through 2006 have a self diagnostic check feature. It will indicate if there is a error or not and point you in the direction of your trouble.
Based on the error code I or others can tell you more based on the error code and the EXACT model number of the set.
Here is what you do if it turns on for a few seconds and then the power light goes off.
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} UNPLUG TV AND THEN PLUG BACK IN---TURN ON---GREEN POWER LIGHT COMES ON FOR A MOMENT AND GOES OFF.
PRESS AND HOLD “Menu and Input"(or device) buttons on front of tv for at least 5 seconds and then release both together.
Watch for power light to blink in a sequence:
1 blink-then 2 blinks-------no error
2 blink-then 1 blink-------X-ray protection
2 blink-then 2 blink-------SHORT PROTECTION*******
2 blink-then 3 blink---------deflection circuit problem
2 blink-then 4 blink---------vertical circuit problem
******2, then 2 is most common---usually means one of the fuses that protect the Convergence IC or IC’s is blown---set will detect no voltage to convergence IC and shut down.
SET WILL REPEAT BLINK ERROR CODE UP TO 5 TIMES AND THEN TO GET IT TO REPEAT MORE YOU HAVE TO UNPLUG SET AND TRY TO TURN ON AGAIN.
IF IT IS 2 AND THEN 2---USUALLY
CONVERGENCE CIRCUIT PROBLEM
If someone has one of these codes and needs help let me know.
SD TECH
on Dec 20, 2009 | Televison & Video
I have a WS65711 - 3 months ago I replaced the Convergence - Today the TV was on then turned itself off. I have tried to turn on but it just turns off after 30 seconds
Did you do the diagnostic self check:
when green power light goes off on the front of the set press and hold both Menu and Input(Device) buttons for 5 seconds and release both.
Power light will blink two digit error code like: 2 pause, 2 and repeat it at least 5 times.
Let me know what code you find and I will try to help you.
SD TECH
Jan 05, 2010 | Mitsubishi WS-65711 65" Rear Projection...
Mitsubishi hdtv1080 won't turn on. green timer light flashing
could be a lot of things really. when you replace the bulb, there is a switch that will prevent the tv from turning on if the cover isn't sitting correctly, by moving it that might have shifted so it would blink, but not turn on. if not, well get it serviced, sorry
Mar 04, 2009 | Mitsubishi WS-55513 55" Rear Projection...
Mitsubishi wd-62825 dlp
If the green front panel LED blinks continuously and the TV never comes on, its an issue with the "DM" board. When these TVs are first plugged in, the green LED should blink for 30 sec. to a minute or so. This is the TV booting up, reading its software. Mitsubishi has been having problems with this circuit for several years. In may cases the only permanent solution is to have the chassis rebuilt by Mitsubishi at considerable cost and inconvience. The chassis may have to be sent back to Mits for this rebuild. Call Mits and ask for help.
michtech
Feb 13, 2009 | Mitsubishi WD-62725 62" Rear Projection...
Screen won't turn on --flashing green/solid green power light
Your main boards are bad. They are no longer available, You have to have the chasis rebuilt. Mitsubishi is rebuilding these chasis. You have to pull it without any cut wires & ship to Georgia.
tvdoctor
Jan 21, 2009 | Mitsubishi WD-62725 62" Rear Projection...
I have a Mitsubishi 65" rear projection TV that has only a fast
having the model number would help.
green light flashing is telling you that it is in shutdown mode.
with model number we could reserch it futher.
thanks,
daniel.
Jan 12, 2009 | Televison & Video
Cannot turn tv on
mine required a bulb replacement it wasn't that old at the time
don't like being turned on and off a lot
Dec 01, 2008 | Mitsubishi WD-62525 62" Rear Projection...
Green blinking light on Mitsubishi WS-55813 HDTV
generally this means a bad digital module.. as a techinican the first thing that we would check are what is know as standby voltages. if they were there we would replace digital module.! question. Does it blink for more than 70 seconds. This unit comes with a lockout feature. to unlock press and hold menu down for 10 seconds on front panel.
Jan 08, 2008 | Mitsubishi WS-55813 55" Rear Projection...
Televison & Video Logo
117 people viewed this question
Top Televison & Video Experts
Electro Med Services...
