Question about Pioneer Car Audio & Video
Pioneer DEH-1050E(looks like DEH-2900MP)has no power after jump-starting with a battery more powerful than mine.fuse in box and at back of stereo look ok.Help
SOURCE: Clock
great job the manual says to hold th e function button thanks
Posted on Aug 09, 2007
SOURCE: PIONEER DEH P 5450
download the user manuel here
http://www.google.com/url?sa=t&source=web&ct=res&cd=8&url=http%3A%2F%2Fwww.pioneer-latin.com%2Fdownloads%2Fcrd3544a.pdf&ei=8yFGSc_ZMJnNmQfu8qHJCA&usg=AFQjCNHK9ZKHmWcKd7wdynYUr9l6U4urNA&sig2=TrSHf4Y4wr1JuF2wgnEM6Q
Posted on Dec 15, 2008
SOURCE: Lost Faceplate for Car Stereo Pioneer Premier DEH-P700BT
e-bay
Posted on Feb 02, 2009
SOURCE: HOW DO YOU CHANGE THE TIME ON A DEH-P59001B PIONEER STEREO
Its not the select button, you must have the power off and hold the function button down for about 5 seconds, display will change and you will be able to navigate your way to the clock from there. Hope this helps.
Posted on May 27, 2009
  • 3 Answers
SOURCE: I installed a pioneer Deh p49001b car stereo in a
to solve the problem with it turning off when u turn your lights on is that on the back side of your radio is a spot that says max and something else keep your ground wires conected just how they are but get u a a 14 to 12 gage wire a cut u about 6 inches and use one end and connect to your other ground wires (with Connecters ) and the other end and with a closed end connecter with the little hole in the center i cant place wat its called but any ways put it where that max hole thing is where there is a screw there and that should fix that problem cause i had that happen before .. but make sure your antentia is pluged iin to ok .. good luck Paul,
Posted on Aug 12, 2009
I need a installation manual for a pioneer radio DEH-2900MP
The Pioneer EU site has the manuals on the product site: http://www.pioneer.eu/eur/products/archive/DEH-2900MP/media.html . Expand the section marked Manuals and the first document is the installation manual. The in-browser link is http://docs.pioneer.eu/Manuals/DEH_2900MP_CRD4131_installation_manual/ and the page has buttons to create a PDF or print the document.
Crutchfield.com has the User Manual and Installation Manual as one PDF on the archived product site: http://wwv.crutchfield.com/p_130DEHP290/Pioneer-DEH-P2900MP.html . Make sure to select the Details tab. The link to the manual will be right below the What's in the box? header. The direct link to the manual is http://images.crutchfieldonline.com/Manuals/130/130DEHP290.PDF . The installation instructions begin on page 33 of the PDF. (Note: you will need Adobe Reader to read the document.)
I hope this helps.
Feb 27, 2015 | Pioneer Car Audio & Video
Pioneer dh 2900mp Can not find aux setting
Unlike the DEH-3900MP, the DEH-2900MP does not have an aux setting (or an aux input port).
Oct 18, 2012 | Car Audio & Video
How do I set the clock on a pioneer mosfet 50wx4 deh-1050e radio
Turn the stereo off. The volume dial has four buttons surrounding it: Left/Right, Up/Down. Press the volume dial until the hour starts blinking. Use the Up/Down buttons to set the correct hour. Press the Right button to set the minutes and use the Up/Down buttons as before. Press the volume dial again to set the time.
Jan 30, 2012 | Pioneer Car Audio & Video
It was working fine I shut the power off and just had the radio playing then turned it off for a few minutes and the car wouldnt start so I had to get a jump now my radio wont work its a pioneer...
Check the fuse panel under your dash, & there may be a fuseable link in the ignition wire behind the stereo also, somtimes when you get a jump it can pop a fuse or 2.
Feb 26, 2011 | Pioneer DEH-2000MP MP3 CD AM/FM Car Stereo...
I have the pioneer super tuner 3 DEH-1900MP. My car battery died the other day we jumped it and it is working fine but i cannot figure out how to turn back on the sterio. How to I turn it back on I've...
I have the DEH-1200MP model super tuner 3 and it would not power up after battery died and was jumped. There is a fuse at the back of the stereo that I unplugged and plugged back in and then the stereo powered up. I had already checked all of the other fuses. Took me a while to figure this out.
Jul 04, 2010 | Pioneer DEH-P690UB CD Player
My car battery died, after giving the car a jump, the car started, but now my pioneer DEH-P2900MP car stereo won't work at all. could you please assist. thanks.
If you have already checked the fuse(s) that supply the radio and none are blown, you may want to try to reset the unit by disconnecting the power feed to it. Keep in mind that the radio likely has two power feeds...one for the ignition and another that keeps all memory functions up and running, even when the ignition is off. Disconnecting both of these may allow the radio to reset.
Feb 11, 2010 | Pioneer DEH-P2900MP CD Receiver...
Radio stop working after battery change
If your radio is the pioneer model stated, it definately has a fuse!
The little black box on the yellow wire contains a fuse.
If there is no black box on the conctant power, you may have damaged the radio with a voltage spike(s) when connecting the battery posts.
Jan 09, 2009 | Pioneer DEH-2000MP MP3 CD AM/FM Car Stereo...
WIRING INSTRUCTIONS
Red=Positive 12v(switched)
Black=Negative ground
Yellow=Constant Power(Battery or fuse box W/ Constant power)
Grey=Right front+
Grey/Black=Right front-
Purple=Right rear+
Purple/Black=Right rear-
Green=Left rear+
Green/Black=Left rear-
White=Left front+
White/Black=Left front-
Blue=Amp turn on
Blue/White=Power antenna
Orange/White=Dimmer
May 29, 2008 | Pioneer Car Audio & Video
Install pioneer DEH-P6400 into 98 dodge dakota, just wont work :-(
Have you measured the 12v ignition and permanent supply?
Also check the earth.
You will need a tester for this.
Check the fuses
John w
Feb 13, 2008 | Pioneer DEH-P6400 CD Player
Car Audio & Video Logo
255 people viewed this question
Top Pioneer Car Audio & Video Experts
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
