Thank you for your prompt reply I really appreciated it. I'm not very hands on can you tell me where the float is ?Thank you for your prompt reply I really appreciated it. I'm not very hands on can you tell me where the float is ?
Think there may be a float switch on there, it should be at the bottom of the dishwashers tub. Look if there is a panel at the bottom of the machine if so I think it's there.Think there may be a float switch on there, it should be at the bottom of the dishwashers tub. Look if there is a panel at the bottom of the machine if so I think it's there.
You can't post conmments that contain an email address.
Error code E3 on a Hobart LXiH sanitizer/dishwasher typically indicates a problem with the water fill system. Here are a few things you can check to troubleshoot and resolve this issue:
Water supply: Make sure that the water supply to the dishwasher is turned on and that there is adequate water pressure. Check for any kinks or blockages in the water supply line.
Water inlet valve: The water inlet valve controls the flow of water into the dishwasher. Check to see if the valve is open and that there is no debris blocking the inlet. If the valve is faulty, it will need to be replaced.
Water level sensor: The water level sensor is responsible for detecting the water level in the dishwasher. If the sensor is not working properly, it can cause the dishwasher to display an E3 error code. Check the sensor for any signs of damage or debris.
Water pump: The water pump is responsible for pumping water into the dishwasher. If the pump is not working properly, it can cause the dishwasher to display an E3 error code. Check the pump for any signs of damage or debris.
Control board: The control board manages all the electrical functions of the dishwasher. If the control board is faulty, it can cause the dishwasher to display an E3 error code. In this case, the control board will need to be replaced.
E3 error in free-standing compact dishwasher 1. Contact an Authorized Service Center.
Error messageE3in free-standing compact dishwasher indicates malfunction of heating element.
We recommend requesting a visit by a service engineer. E3 error in integrated compact dishwasher 2. Contact an Authorized Service Center.
Error messageE3in integrated compact dishwasher indicates too much inlet water and/or a leak.
check power supply if have power going to panel then it is assumed that theirs a short in wiring somewhere if no power to unit check your breaker or power connection
E3 fault is caused by the water reaching the required temperature or taking too long to reach temperature. It will be either a malfunction of the temperature sensor or something wrong with the heating element.
It is very likely the fault is coming from the water heater element.
Will need to replace the two heating elements. Maybe a bit hard to get the parts. Your best bet online is Partsmaster. But not sure if your model is still supported. call them up.
All codes E01, E02, E03, E04 and E05 all indicate a power module failure. Please test the following with the VOM. Sounds like a door switch problem here. Make sure you door closes and latches properly. If it does, you must gain access to your door switches and check for proper continuity and OPS of switches. Can also be a keypad or control issue, but make sure your switches are good first. Of course you must test the output outlet from wall, reset the c. breaker see the diagram attached, observe the polarity very IMPORTANT. God bless you
