Question about MagLite Charger System for
Change bulb on the 3 amp mini mag
On the $20. mini mag I can't figure out how to get the bulb out of the flashlite or the spring from the bottum piece?
Pull the bulb strait out it should have two pins,the spring in the bottom also pulls out ,there you will find your extra bulb.
Posted on Jul 24, 2009
I have a 95 trans am with an automatic 4l60e transmission that will not go in to any gear, what could be the problem?
How old is the transmission?
If it is original from 1995 some 20 years,
I wouldn't even try to figure it out
Just pull it & rebuild it
If it has worked well for the last 5 years & is
only 8 years old, you could have it diagnosed
If you never change the fluid every 3 years,
it's shot, most likely.
Sep 28, 2014 | Mag Hytec mag4l60e/700r4 gm 4l60e/700r4...
I can't open a mini mag light to change batteries.
Twist off the opposite end of the bulb side , the hole in the cast of the cap is for your keychain ring.
Aug 08, 2011 | MagLite Mag-Lite& Flashlight
Cant open battery to change.Mini Maglite
My Mini Mag light has a knurled cap on the end opposite the light bulb. It should unscrew to reveal the AAA batteries.
Jan 16, 2011 | MagLite Mag-Lite& Flashlight
I removed the backing of the flashlite to get the bulb
The extra bulb in there could be broken, get another bulb and confirm.
Apr 24, 2010 | MagLite Flashlight Type: Black D Cell 5:...
MAG-Lite flashlite with Battery removal problem
Pull the cap off the end and wack it in your hand or a piece of wood, don't swing it like a baseball bat. Sometimes they get stuck in mine also, Not sure why, but a good wack gets the job done. Don't worry, the flashlight can take it.
Feb 04, 2010 | MagLite Mag-Lite& Flashlight
Tried to change bulb but now wont work
Insure the batteries are working correct and in the proper direction. Also double check the bulb to isure it was not damaged and put in correctly. If it was working before new bulb inst. try a new bulb
Jul 30, 2009 | Mag Instrument AAA Mini Maglite...
How do you change the bulb in a mini maglite?
Carefully.....
Check in the base of the torch and you will see the spare bulb. you need to pull the spring out to get at it.
Next unscrew the top off the torch to expose the bulb.
The bulb is easily removed by gently pulling straight out. Replace the new bulb in the same way, lining the two pins up with the holes (doesn't matter which way round) and wipe the bulb clean of any finger grease etc.
Screw the top back on and replace the spring in the base before screwing the base back on..
Replacement bulbs, and all other parts for that matter, are easily sourced at any good outdoor store that stocks MAG.
Hope this helps..
Jul 05, 2009 | MagLite Mag Lite Led 2 Cell Aa Flashlight...
How do you change the bulb in a minimaglite
1. Unscrew the "bell" (top) of the flashlite. 2. Remove the bulb by pulling upward. 3. Replace with new bulb (be sure you have the correct bulb . . . it will have two small wires protruding from the bottom). 4. CAREFULLY insert new bulb through hole in the bottom of the reflector. 5. Screw the top of the flashlight back on.
Oct 22, 2008 | MagLite Camping, Backpacking & Hiking
MagLite Charger System for Logo
245 people viewed this question
Top MagLite Camping, Backpacking & Hiking Experts
David Black
David Black
Level 1 Expert
 steve
steve
Alec Oren Orris
Level 1 Expert
Are you a MagLite Camping, Backpacking and Hiking Expert? Answer questions, earn points and help others
