Brett Duxbury. You always have great answers, why do you hide them up there!
Brett Duxbury Feb 26, 2022
Hi Catrina , Check the spark plug - may need a clean.
Check for an air filter may need cleaning
Check for an off switch
that stops the engine labelled as engine switch left hand side of generator panel
was choke on when starting it ?
Can you please add details in the comment box?
fuel does fuel line have a tap fitting and is it in flow setting rather than off ?
Remove the generator from the generator bracket and position the generator above the drive axle.
Remove the drive belt tensioner. Refer to Drive Belt Tensioner Replacement in Engine Mechanical-3.4L.
Remove the generator bracket. Refer to Generator Bracket Replacement .
Remove the power steering pipes from the power steering pipe retainer.
Remove the fuel pressure test port (schrader valve) cap from the fuel injector rail.
Important Do not disconnect the power steering pipes from the power steering pump.
Remove the power steering pump and reposition the power steering pump in front of the timing chain cover in order to provide access for the generator. Refer to Power Steering Pump Replacement in Power Steering System.
Remove electrical harness from retainer on right fender well and position aside.
Chargers will out last batteries by a long time.You will need to get a new battery. Black & Decker is a cheap household brand and does not hold up for long periods of time. I have better brands and buy several new batteries every year.
Some Coleman generators have rectifier /diode pack behind panel others have a diode inside generator cover however when diode fails it usually fries the winding. Your winding could be within the generator or under flywheel depending on model#. If your generator had a fuse to protect winding then test diode and replace as necessary. You may also just plug a small battery charger (1 or 2 amp ) into 115v plug to charge battery / power coil. Good luck and email if you have other questions.
