SOURCE: error message f-01 on hotpoint ultima wt741 washing machine
F01 is a motor faulty normally caused by the module,but sometimes thewiring to the motor plug that works loose as its to tight,give them alla good wiggle make sure there all in!
check this link for other error codes of hotpoint machines
http://www.hotpointservice.co.uk/hs/pages/content.do?keys=FAQ:ERROR_CODES
SOURCE: need to set clock on my cannon chichester oven
Go to www.cannonservice.co.uk/hs/pages/manual/manualSearch.do you should find your model there. Terry.
SOURCE: clock on cooker flashing
Just to let you know that i have solved the problem with my cooker, (clock flashing after electric going off) i held down the cook period button and the end time button, then i was able to reset the clock by pressing the +button.
SOURCE: hotpoint ultima F-05 errorr appears on machine
Error F05 indicates pressure switch jammed on full.
Remove lower rear cover of washer.
Locate and remove large black hose fastened to drum.
Remove and clean filter inside hose.
Remove hose onto pump, and check for blockage or obstruction here as well.
This should solve the problem.
