Question about Refrigerators
Refridge door does not close evenly on my side by
Refridge door does not close evenly nor does it stay shut on my side by side
    Problem Solver:
  • 15 Answers
Top hinges can swing right to left slightly when all 3 screws are loosened under removable cover. Use a 5/16 nut driver. Hinge cover may be phillips, 1/4" or 5/16".However, fridge case must be level left and right first. Level fridge with adjusters behind toe kick cover. Once level, you can adjust gap between doors with top hinge movement. Keep in mind that this is a man-made product and you may not get the doors exactly straight due to lose manufacturing tolerances.
Posted on Jul 24, 2009
My problem was the door on the opposite side of the hinges had a gap of approx. 1/32". i unloaded the shelves on the door and then it closed tight. there was too much weight on the door problem m
solved
Posted on Jul 29, 2009
  • 670 Answers
1. You should be able to loosen the bolts that hold the door hinges(loosen only enough to be able to move the hinge) and move the door to the stright position. Retighten the bolts. 2. Check for obstructions that may keep the door open. If none, simply adjust the front of the frig upward to help keep the door closed. Usually the front adjustment screws are behind the toe kick panel on the front of the frig. 3. I advise that you also check the condition of the magnetic door weatherstrip.
Cant adjust temperature
check to maker sure lights are going off when door is closed , if not it will get extreamly hot ibn refrigerator and cause lights to go off and stay off til cool,
Nov 29, 2013 | GE CustomStyle PSC23NSTSS Stainless Steel...
Amana Br22tw refridge door won't stay closed
Check all the screws for the hinge and be sure the door is lining up properly.
Oct 23, 2012 | Amana ABB1927DE Bottom Freezer...
If light stays on will refridg over heat?
The answer to your question is no,your refridgerator will not over heat. If you don't want to replace door switch you should be able to remove bulbs to shut off lights. I would try working door switch several times to see if it's just not closing all the way. Hope this helps. Thanks
Nov 15, 2010 | Maytag Refrigerator Light Switch -...
REFRIDG DOOR OPENS A LITTLE WHEN I CLOSE THE FREEZER
Yes I think it's the door closing cam broken and worn away.To replace, Leave the door shut and let the magnetic gasket hold the door in place. Put something between the bottom of the door and the floor to hold it in case it slips. Remove the bracket holding the pin and hinge assembly taking note of order of removal of parts. Slide new cams on. You probably need two.
Aug 30, 2009 | KitchenAid KSCS25FKSS Side by Side...
Refrigerator light stays on even when door is closed.
Turn off the Low Ambient Switch on the upper panel of the Refrigerator door. That will turn it off.
May 06, 2009 | Dometic NDR 1292 Refrigerator
Refridgerator door doesn't close good
Hi there check that the door hasn't been pushed open too hard and stressed the hinge area,and if so try carefully tapping the hinges back.hope this helps.
Dec 20, 2008 | Kenmore 53642 / 53644 Side by Side...
Freezer Door Won't Stay Shut
OK LOOSEN THE HINGE THAT SUPPORTS THE FREEZER DOOR.IT'S ON TOP AND HAS 3 SCREWS .JUST LOOSEN AND NOT REMOVE THEM.NOW LIFT UP THE DOOR UNTIL IT LINES UP EVEN WITH THE OTHER DOOR.AT THE SAME TIME TIGHTEN ALL 3 SCREWS. YOUR DONE!!!
PLEASE RATE THIS. THANX!!
Jun 06, 2008 | GE GSS25QSTSS Stainless Steel
My refrig side door does not stay closed
I'm having exactly the same problem. Did you ever find a solution?
Michael mpelzsherman@yahoo.com
Apr 06, 2008 | Refrigerators
Kenmore Elite side-by-side (1999 model--don't have #)
Evaporator is probably overiced as a result od door not being completly closed at some time recently, turn off and defrost overnight with the doors open, turn on the next day and it should work ok within 24hrs. Regards Advisor
Aug 14, 2007 | Kenmore 57029 Side by Side Refrigerator
Refrigerators Logo
339 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
